How many chains & binders?
/ How many chains & binders? #1
coolbrze
Gold Member
VA
Kubota MX5800
Moving my MX5800 w/ FEL & cutter. How many chains & binders do I need on the tractor - 4? What about the FEL & bush hog?
/ How many chains & binders? #2
If I'm not mistaken, you need one for each corner of the machine and and for the loader attachment and one for the attachment on the back.
/ How many chains & binders? #3
Legally, if the load is under 10,000 lb you only need 1 front / 1 back / 1 FEL / 1 BH.
For peace of mind I use 4 chains for tractor, 1 for FEL and 1 for any 3 pt. implement.
I use 5/16th Gr 70 chain.
/ How many chains & binders? #5
When the dealer delivered my M6040. One chain on each corner - - one chain across the bucket on the FEL - - one chain across the rear blade on the 3-point. Six chains.
/ How many chains & binders? #6
Here is my understanding:
Tractor > #10K, chain on all four corners
Tractor < #10K, 3 chains
Combined weight capacity of the chains must equal 50% of the weight of the tractor
Thanks everyone. I have 1 (5/16" G70) on each corner but used HD ratchet straps on the FEL & cutter. Is this legal or do I need chains & binders on the loader & bush hog?
/ How many chains & binders? #9
You'll be fine as long as the straps are sufficient. I use 4 chains (5/16", G70) for the corners. Straps (3,3333 pound working load limit) for the FEL and any other implements on the trailer.
I'm amazed at some of the people I've seen securing loads with light weight ratchet straps. Just make sure your straps meet the load they're expected to secure.
/ How many chains & binders? #10
This is correct if doing indirect tie down as in the chain or strap hooks on one side of the trailer, goes over or through something and then hooks on to the other side of the trailer. For direct tie downs as in the chain goes from the trailer to the tractor and attaches to it directly the WLL of the chain is cut in half for the purposes of the securement calculation amount and thus your chains need to add up to 100% of the weight of the tractor.
2011 AMERICAN 14 T/A DOG HOUSE (A65643)
2011 AMERICAN 14...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2yd. Skid Steer Trash Hopper (A65640)
2yd. Skid Steer...
2018 RoGator 1100C (A63689)
2018 RoGator 1100C...
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
2006 Ford F450 XL Super Duty Swab Rig (A62679)
2006 Ford F450 XL...
