Pallet Fork Extensions?
/ Pallet Fork Extensions? #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
The snowmobile dealer has 8-10 long pallet fork extensions so they can pick up a snowmobile from a van or trailer.
Anyone make their own? Out heaviest sled is about 650 lbs but believe our forks are 42 and don稚 extend far enough.
/ Pallet Fork Extensions? #2
Someone gave me some home made ones. They are ugly and heavy, but have been handy on occasion. I believe they are made of two channels welded together maybe 8 feet long. The end is cut on a bevel and there is a hole cut in the end of each extension for a chain. I have used them on occasion to extend my reach when wanting to lift something, over something else.
/ Pallet Fork Extensions? #3
6 Standard channel with the web facing up. Taper the outer end and box the underside beginning 4” from the back end and extending a foot or so forward. Box another section near the end of the 42 forks. Cut about 3” of the web out of the back end and drill the flanges to accept a 7 x 1/2 pin going through the holes and behind the bend in your 42 forks.
/ Pallet Fork Extensions? #4
These work for me.
/ Pallet Fork Extensions? #6
You can just buy heavywall rectangle tubing. Easiest way to get it done.
But the further forward you go, you quickly loose hydraulic lift capacity. So with a L3200 and fork extensions, a 650# snowmobile might be a struggle.
Forklifts lift vertically......so extensions dont reduce its actual capacity in terms of hydraulic power at all. Stability.....sure. But not hydraulic power.
/ Pallet Fork Extensions? #7
My L3200 would lift "1,200lbs" hay bales plop n the forks. But I couldn't lift the the lightest of the bales if they were 1' out. I couldn't lift some of my impliments on the tips of the forks unless I choked up on them closer. I'm guessing I'd lost half the lift capacity at under 4' out from the back of my forks. Add in a couple hundred lbs for extensions & it's going to be very iffy to lift your 600lbs sleds.
/ Pallet Fork Extensions? #9
Just yesterday I was looking for fork extensions....I'm going to need to move a 2700 pound piece of equipment into a trailer. The machine is 11.5 feet long, 40" wide and 6' tall... it has to go in from the back of the enclosed trailer. I'm reading that extension forks can be no more than 50% of the existing forks..i.e. 4'forks, can only have 2' extensions.. that load I need to move, I think I'm going to need to rent a tele handler to do it...2700 pounds 11 feet out..is going to be sketchy
/ Pallet Fork Extensions? #10
Not sure on the 50% of existing forks. Where did you see that?
I have seen industrial lifts and heavy duty extensions used all the time. 8' extensions on 4' forks, etc.
Vertical Steel Well Tank (A61570)
Vertical Steel...
Toro z turn (A56859)
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2021 KENWORTH T680...
1995 John Deere 7400 (A60462)
1995 John Deere...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
