Todays shop time.
/ Todays shop time. #521
I like the way that works - very clever. Not knowing much I have a question. What are the the spacer/washer/leveler things between your vise and stand table. Thanks.
gg
Hi Gordon, I used Click Bond studs. They are adhesively bonded to the bare metal. No drilling or welding necessary. I work for Click Bond so I use the products all over. Lots on my tractor, etc. great for mods.
/ Todays shop time. #522
Thanks - I am not familiar with those. Look like a great product for mods and all kinds of stuff !!
gg
/ Todays shop time. #523
Someone (maybe you) used the Click Bond studs to mount LED work lights on their tractor ROPS to avoid drilling.
/ Todays shop time. #525
Yeah that was me.
Thought so. Will you be sending out “free samples” to TBN Nation?
But seriously, does Click Bond sell thru dealers? Are there sources here in Texas?
Thanks!
/ Todays shop time. #527
Yeah that was me.
HMMMM. I bought some super strong magnets to try to do the same thing, worked for another TBN'er.
If the 130 pound magnets don't hold the one pound light on, now I know to check out Click Bond.
Ya know, we all clean up a little before taking pics but gosh some of the shop pictures I look at are so clean
I feel like an utter slob cleaning mine up once or twice a year. And who of us hasn't gone to take a pic and you look at some
junk in the background and you move the camera to hide it. It's not junk though, projects in queue!
/ Todays shop time. #528
Got tired of having to get out a 15/16 wrench and the rattle gun whenever I wanted to drag my pin-hitch grass sweeper behind the ZTR, so I picked up 3 of the HF "ATV hitch adapters" - the ZTR just had a piece of FB with a hole for the hitch ball, welded onto the 3" angle across the back. I cut that FB off flush with the angle, and welded it (with the ball still on it) onto a piece of 1/4" wall 2" tube, and made another with just a hole in the FB for the pin hitch -
Then I put another one of the ATV hitches on my recent CL find; an older Club Car golf cart - had 6 months on new batteries, good tires, full enclosure and separate cover, all for $400 :cool2:
Notice all the washers in the last pic? There's even more ABOVE the hitch; the existing 1/2" hole was in the lower "stake pocket" lookin' piece AND the upper area (where the golf bags are NEVER gonna sit again :D) - the washers you can't see took a little fiddling around to get where they needed to be, I didn't want to bend either of those pieces so the washers gave me a snug fit BEFORE I tightened the 1/2" bolt.
I have one more of those ATV hitch adapters, thinking about a FRONT hitch on the cart for jockeying a couple of the smaller trailers around... Steve
/ Todays shop time.
I lost one of the ramps to my trailer so I made another one. It’s amazing how much faster projects go using new metal.IMG_4092.JPG
/ Todays shop time. #530
I have a little 3000 lb capacity dump trailer with 12" removable sides.
I want to put some stake pockets on it. Two on each side and two in the front so I can have a staked flat bed or add extension sides to give me a 3' tall box. The skin on the bed is only 12 gauge ( .104" ) and the side rails were made by folding the bed edge into a "U". So I need to beef up the side rails where the stake pockets will go. I took the bed off and flipped it upside down so I can work on the bottom. I am using some channel made from 2X2X1/8 angle. I cut two slots in the rail so I could drop the channel straight down and used a couple C-clamps to bend down the rail between the slots.
The bed was pushed down in some places from hard use so I made a hook and hung some weight on a bar to push the bed and channel up so I could tacked it flat.
This is as far as I got before it started raining again. I found welding this thin material a challenge.
gg
/ Todays shop time. #531
Nice trailer Gordon and looks like you are having fun.
I keep looking at the very front of that trailer and wonder how you pull it.
Does the front swivel or how does it work horizontally?
/ Todays shop time. #532
Yes it rotates and normally hooks onto a draw bar. It is made for field use where it is more or less flat. I use it in the woods so I made a swivel so that it doesn't bind on the draw bar in dips and on sharp crowns so it gets rotated 90*.
gg
/ Todays shop time. #534
Mark, nice job. I admit I still don't understand how the fasteners work, you add some epoxy glue around the center area and then push in? Maybe I missed that in the video. Is there adhesive inside the fastener? I bought some magnets to do this for lights on a rollbar and now I think this is a better solution.
/ Todays shop time. #535
Sorry, unfortunately my video capture missed the application of the adhesive. Yes, you apply adhesive around the center 'sticky back' tape. I added some captions and links on YouTube for more detail.
Here are the official install videos for internal and external fixtures parts direct from Click Bond website...
:: Click Bond, Inc. :: Video: Installation of Internally Fixtured Fasteners
:: Click Bond, Inc. :: Video: Installation of Externally Fixtured Fasteners
/ Todays shop time. #536
that's easy, thanks!
/ Todays shop time. #537
I cobbled together a stand for a shop vacuum hose to hang on at the drill press. The base is leftover concrete that I let setup in a bucket and later drilled a hole into. Some 1/2" PVC pipe and a leftover metal dowel from Mrs.tillers flower garden makes the upright. The 90 degree clamp thingy is from a project back in the 80's. No money involved it this one, just time hunting through the junk piles.
Nice job bigtiller! I always like to see how people repurpose unused items.
I “rescued” some tables and bar stools from the scrap bin a while back. Today I “added” an Olympic dumbell for a foot rest and put it in my home gym. IMG_0566.JPG
This 100# umbrella stand came from the same scrap bin. I used it as a base for my portable battle rope anchor pole.
/ Todays shop time. #538
Smart thinking! Excellent use for a dumbbell. How did you "add" it on?
/ Todays shop time. #539
I hole sawed through the table pedestal and tacked the dumbell handle from the underside. Used 2” locking shaft collars for the plate “clamps”
/ Todays shop time. #540
I 途escued some tables and bar stools from the scrap bin a while back. Today I 殿dded an Olympic dumbell for a foot rest and put it in my home gym.
:thumbsup: I have to spend more time in the recycle dumpster!
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
2017 Jeep Renegade SUV (A61574)
2017 Jeep Renegade...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
