Front loader for a Kubota B7100
/ Front loader for a Kubota B7100 #1
smfick755
B1700 Kubota
Would anyone know what Hyd. pump would be the best for a front end loader we are fabricating for a B7100 Kubota
/ Front loader for a Kubota B7100 #2
What size cyls are you going to be using? Is the tractor 4 WD and does it have power steering? Your tractor hyd flow is 3 GPM.
/ Front loader for a Kubota B7100 #3
I've used a 0.36 ci pump on the loader I've made for the B7000 I used to own. It worked just perfectly. Just the right speed and it would even allow me to do 2 functions at the same time. But then again, it all depends on the size of your cylinders.
The lift cylinders if I remember right were around 1.5" bore and the curl had around 2 1/4" bore.
