Open center vs. close center
/ Open center vs. close center #1
Groo
any good primers out there discussing the pros and cons of each system?
Open center = fixed displacement (for the most part) and closed center = variable displacement.
What is there beyond that? What can closed center do that open centered can't? Anything else out there?
/ Open center vs. close center #2
Google would give you lots of reading material. Aircraft have always used closed center. You only need a pipe big enough for the flow required by each component, not the entire pump flow, so it saves a lot of weight. Also you can operate more than one control at the same time. Important if you don't want to crash.
/ Open center vs. close center #4
With a closed center system pressure lines can be tee'd
I have a Ditch Witch 3610 and it has both open and closed center systems...
/ Open center vs. close center #5
Closed center is far more fuel efficient and heat efficient. It only uses what oil it is told to move by the pilot oil input from the operator. And flow adjustability with L/S pump is good for motors and such that require a certain flow to work safely.
/ Open center vs. close center #6
Chevy is exactly correct. Heat is the issue, very destructive. I have a older IH tractor, open center, and the hyd operating temp pushes the boundaries even if no oil is feeding a motor or cylinder. It is very rare to find closed center systems in sub-100 hp tractors.
/ Open center vs. close center #7
Closed center hyd system that develops a high pressure internal leak can have heating problems. More fuel efficiency is determined by number of hyd functions that are performed. My guess is a 50 or 55 series JD tractor hyd pump is out of stroke for a very limited amount of time. Then when operating a hyd motor it never goes out of stroke.
/ Open center vs. close center #8
Internal leaks are considered a malfunction.
I will have to disagree with you on the fuel efficient statement. If you took 10 circuits for both types and both running all hyd motors a closed center will out perform an open center all day long. You can tune a closed center to match needed flow. The open center is all or nothing.
/ Open center vs. close center #9
Have you ever operated an orbit motor on a JD CC hyd system? Evidently not.
/ Open center vs. close center #10
Once or twice
/ Open center vs. close center #11
On the pump never going out of stroke comment, that would be true on a motor requiring 35GPM with a pump output of 38+/-. What is nice with cc is you can have a pump capable of 3x the needed flow. But like stated before, most CC systems are not under100hp
/ Open center vs. close center #12
Orbit motor? Are you referring to a travel motor? As far as I know all hyd motors are used in a rotation function
/ Open center vs. close center #13
I don't know much about this topic, but there are lots of long nose John Deeres that are closed center and under 100 hp. Our 2155 has 55 engine hp and the loader operation is smooth as glass and powerful. Have no complaints at all about the hydraulics on that tractor.
/ Open center vs. close center #14
True ..... I'm a construction guy so don't do a whole lot on the small green ones
/ Open center vs. close center #15
Gary, my error.
Many deere 50-60 series tractors, even lower hp models were closed center. These were from early 1990's perhaps some from late 80's.
Fast fordward to 21 century, hard pressed to find a AG tractor <100 hp with closed center hyd. Exclude some speciality Models NOT designed for AG row crop or utility chores. Regret my generalized characterization.
/ Open center vs. close center #16
Gary, my error.
JD 20-55 series utility tractors built from '65-'92 with hp ranges from 38 pto to about 100 pto all had CC hyd's with a few exceptions such as models 830 & 2040 with 3 cyl engines that had OC hyd's
/ Open center vs. close center #17
Sorry I have no clue what a "travel motor" is. Below is a photo of orbit motor.
/ Open center vs. close center #18
All motors are an orbit rotation. Aka they all turn as fast as they "told" to via flow. A travel motor is a motor that turns a tire or final drive gear box.
/ Open center vs. close center #19
So is a travel motor hyd powered?
/ Open center vs. close center #20
Yes. It's the same ( can be ) as what you showed. But they can get more complicated than a fixed displacement one like you showed. I deal with alot of this type.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Chevrolet Express Van, VIN # 1GAZGZFG5F1104801 (A61165)
2015 Chevrolet...
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
207269 (A52708)
207269 (A52708)
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
