Good morning!!!!
   / Good morning!!!! #74,932
It's sunny here today. need to get out and do some yardwork, between doing tax files.
the baby chicks are content and growing in the garage
coffee is my friend today
buckeyfarmer - could there be some sort of plastic plug jammed in there ?
   / Good morning!!!! #74,933
64°F and .09 inches rain
Off to the PO this morning, town this afternoon.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #74,934
Good morning to all! Low about 45, up to near 70. No rain, breezy. Today should be another nice day.
Went outside and took some measurements on the new property relating to positioning of the new house and garage. Planning ahead for fencing, parking /turn around, and enclosing a "backyard". Wifey is already planning out the backyard water feature and landscape (house isn't anywhere even close to being built yet) Should end up being about 500' of post and rail fencing.
After that, I took advantage of the nice weather and finally drilled the holes and installed tie down loops (6) on the trailer. Figured I better get it done, going to be hauling a lot of materials soon.
Knee is getting better....I'm getting restless...things to do...
Drew, just take whatever seeds you have left, mix them all together, plant those last few rows....would make an interesting experiment. :confused2::D
RNG, glad your gathering went well. Always nice to have friends get together.
Randy, hope you get over the spring crud soon. Don't push it too hard, sounds like you have a lot to do.
Prayers out this morning for everyone. Have a great start to the week, enjoy the day!
Leave plenty of turn around room....
   / Good morning!!!! #74,935
No, found someone on a polaris ranger site with exact same problem. Apparently piss poor construction of the receiver.
   / Good morning!!!! #74,936
buckeyefarmer - that's not good, I hope that you can get it fixed / replaced easily. I have a utility trailer where the coupler is hit and miss - very annoying
   / Good morning!!!! #74,937
I mowed the grass, sounded like I had death rattles when I finished. It’s amazing how much exertion a fast ZTR causes. I wore my mask as always. Took me half hour or so to get back to breathing semi normal. I feel pretty well but the breathing isn’t there yet.
   / Good morning!!!! #74,939
I thought it was the two ridges on the bottom, but it's the lower sides. Theres plenty of room top to bottom. The receiver is made with a piece of upside down u shape, then the bottom piece is welded on. Tbe sides are simply too narrow. No easy fix.
You can see how far the hitch can go. I did wire brush it good, and tried all 4 directions. Will try another 2" hitch, when i find it. 0423181905a.jpeg0423181905.jpeg0423181901a.jpeg
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
Stout Brush Grapple (A59814)
Stout Brush...
Deere 350G LC (A53317)
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
Makita Impact Drill with Charger (A57454)
Makita Impact...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
