kthompson
Elite Member
- Joined
- Sep 12, 2008
- Messages
- 3,526
- Location
- South Carolina
- Tractor
- Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
I live on basically flat ground, however my mother in laws side yard had good slope to it degree wise, not length. I have a B2710 with a Bushhog brand RFM, 72 inch wide. It will climb it fine in mid range but no fel or loaded tires or any thing else other than me to the base tractor weight. I think you need more hp for that grade for with my B2710 on flat ground in my thick places of lawn grass have to run slow just the mowing load which I doubt is more than the weight you are pushing.
Do try running up the hill with all that wTeight with the pto off to be sure no issue with the mower such as with gear box or a spindle or pulley. Or even the pto shaft. Have you done any hard work with the tractor, even heavy work with FEL? Did it drop rpms as easy with that? If not tells me the tractor is fine, however if it is might have a fuel supply issue or air intake issue. Machines come from new with bad filters or trash in them from time to time. Had new pickup in 1973 that about whipped dealer to find out the fuel filter on new truck was bad. Another had new large truck come with defective fuel pump. Different brand and dealer but both had hard time finding the issue.
Good job on the video and nice looking place. Just wondering if you said I missed it, did the dealer recommend this combo knowing anything about the slope of your place? If so think I would be upset with them.
