PICTURES ONLY thread
/ PICTURES ONLY thread #502
IMG_20180415_134724_hdr.jpg Springtime in Alaska. Time to change out the studded snow tires.
/ PICTURES ONLY thread #505
Good eye! Yes, always have had great luck with Cooper Tires.
LOL, I run them with studs on my plow truck. I have't found a better tire for snow plowing.
Here's a pic of my LS in action
/ PICTURES ONLY thread #507
here are some pics of that LS quality from an MT125 IMG_2125.JPG this is after 13 hours of use on a new tractor
/ PICTURES ONLY thread #510
back up and going foward, evidently its very week 8mm stock its the linkage that controls the pedals IMG_2122.PNG #6 on the drawing, 3rd breakdown in 13 hours so hopefully 3rd time is a charm as the last one . lol
/ PICTURES ONLY thread #511
2011 S3010 with 320 hours, top added from a ez go golf cart. I made a couple brackets and re-used arms off golf cart. I plan on mounted some LED style lights to the roof front and back.
/ PICTURES ONLY thread #512
Delivered Today, 2018 XU6158 with LB3102 Backhoe. It came standard with three rear remotes, Creeper Gear, lever to lift the three point in the rear and some kind of PTO cruise control, I did not expect it to have all that when I ordered it. LS over delivered, Proud new owner.
/ PICTURES ONLY thread #513
Upgraded my XR4046HC to an XR4155HC back in November. Got 3 remotes, rear 3 point control, and still trying to figure out the PTO RPM resume deal. Been doing dirt work but will be mowing soon so .... need to read the book ... I guess?
/ PICTURES ONLY thread #514
Can you show me a pic of the creeper gear lever?
I don't think my 6168 came with one, although the manual mentioned it.
/ PICTURES ONLY thread #515
Mine doesn’t have it either. Not sure what I would need a creeper gear for. Low gear is pretty darn slow as is.
/ PICTURES ONLY thread #517
Mine doesn稚 have it either. Not sure what I would need a creeper gear for. Low gear is pretty darn slow as is.
It's next to the differential lock and pulls up like the 4wd. I have not tried it out for the same reason, I can't see going slower than range 1, first gear. I will have to try it out and get back to you. I haven't turned on the pto either, no reason to yet.
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
29 x 9.0 x 15 Tires with 5 Lug Wheels (A61573)
29 x 9.0 x 15...
Unverferth 632 (A64119)
Unverferth 632...
