IH 574 pto problems
/ IH 574 pto problems #1
Slfutrell
Cadiz Ky
IH 574
I just purchased a IH 574. Should the pto turn when my tractor is not running? It turns almost a complete turn. If it's engaged or not! When I start the tractor it will not turn. Even when the lever is engaged.
/ IH 574 pto problems #2
That sounds like exactly how my 584 PTO works,,,
So your pto isn't working either CADplans
/ IH 574 pto problems #5
When engine is running and the PTO is NOT engaging oildrag will take the intenal plate to the internal stop. If you force it anti-clockwise you will be able to turn it for that almost a turn.
/ IH 574 pto problems #6
I had the same tractor, only an industrial model called the IH2500b.
If you start the tractor and engage the PTO lever, the PTO shaft should turn. If it doesn't, something is wrong. With the engine off and the wheels blocked and the parking brake engaged, move the range selector around back and forth between L, N, and H ranges back and forth several times. Put it in N. Then move the PTO lever back and forth several times, then leave it in the disengaged or OFF position. Start up the machine. Move the PTO lever to the engaged or ON position and observe the PTO shaft. If it still isn't moving, I'd first turn everything off again and start looking at the linkage for that lever to make sure it hasn't become disconnected from anything. I'd have to look at my manuals to see how its connected.
/ IH 574 pto problems #12
Moss
Thought your IH was a TLB? My 2400b did not have external pto shaft. Still own a 484, can rotate shaft w/ engine off. Your TLB was a hydro. Mine had a power shuttle, but a gear trans. 4 speeds. Synchro shift. My BH was NOT detachable.
/ IH 574 pto problems #13
No, my 2500b was a tractor loader with a 3pt hitch and PTO on the back. No backhoe. It was HST. Gas engine (c200, I think).
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
LMC 24 Row Boom Sprayer (A64126)
LMC 24 Row Boom...
2008 Ford F-350 (A64127)
2008 Ford F-350...
20' CONNEX BOX (A65643)
20' CONNEX BOX...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
John Deere 6145M (A64126)
John Deere 6145M...
