LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,448
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I run 5w-40 full synthetic in any diesel that is going to be started in the winter, I am one of those people that started using synthetics a long time ago
about 1976 for it's cold weather starting ability, and was impressed by it's hot weather and severe use protections.
I have had an oil filter broke off on a stock car, made a full lap drove into the pits checked it out replaced the filter refilled the engine
and was back out the next heat, I don't believe a conventional oil would have done that. I broke an oil pump drive on a warmed up 390
didn't catch it till the lifters were clattering shut it down checked oil level restarted, shut down pulled the sender out, restarted shut it down towed it home
dropped the pan found the cause repaired it and drove that truck for another 50 or 60,000 miles again I don't believe conventional would have done it.
So I have had good experiences with synthetics I know engines I have torn down have shown less wear then others and I know that the engines start easier and get oil pressure faster
in the cold weather so between Shell T6, Mobil One and Amsoil I have and will continue to use synthetics in almost all my engines and also gear lubes and greases.
My newest tractor with a power shuttle has Syn-Pe-Co multi purpose in the Trans/Hydraulics.
So I will always recommend synthetics, the manufactures recommendations are the minimums allowed I don't care for minimums on hardly anything (bikinis excepted)
