Help me decide on a tilt deck trailer.
/ Help me decide on a tilt deck trailer. #1
mopardude318
Hollister Ca
Kubota M7060 HD12 Oliver 550
I'm looking at Diamond C gravity tilt deck equipment trailers to haul my M7060. From loader to box blade it's almost 20 ft long. I will also use the trailer for cars, and trucks. I am over carrying heavy ramps, that is why I want a tilt deck, and these seem to operate very nicely.
The options I'd like are 18,000 lb GVWR, which has 2 8k oil bath axles with larger electric brakes, and the 17.5 tires. It has the 8"x15lb I-beam frame upgrade.
I think I want the 6 foot stationary deck with 16 foot tilt deck, so a 22 ft deck total.
I'm pretty sure I want gooseneck, my truck is an '02 Ram 2500, I think it'll handle gooseneck much better.
I'm including a bunch of pictures of something they have similar to what I want. What do you think?
There is also a 20 foot bumper pull, 4 ft stationary deck
/ Help me decide on a tilt deck trailer. #2
Sounds good to me. The truck will pull much better with a GN with that tractor behind you. One thing I'd be concerned about is how your combination registrations work in CA. In PA, they will look up your particular truck and tell you what your max registration combination weight is if the information is available to them. I can't tell you what years that is exactly off the top of my head. They no longer let you say I have a super ram and I want to pull 40klbs because I'm a farmer. The reason why I say this is that I had a 2005 3500 ram and I don't think I would have been legal registering an 18k trailer for behind it. If you de-rate the trailer then that is a moot point. If CA doesn't follow the manufacturer's recommendations then its also a moot point. Just something to look into before you drop the coin.
/ Help me decide on a tilt deck trailer. #3
Where is the center of weight of the tractor and implements? How does that compare to the center of the tilting part of the trailer. You are probably ok but it may pay to verify.
Myself I don't care for a tilt deck but I am in an area that gets lots of snow. Driving a tractor up on a tilt deck that has a layer of snow/ice on it could get interesting. I do like the idea of the convenience though.
/ Help me decide on a tilt deck trailer. #4
Looks like a nice trailer. I've had full tilt trailers since 2006 and like them a lot. Current trailer is a bumper pull PJ model TF, 22' 14K rated. Power up and power down. Actual deck length is 23'9" including the tail though its called a 22'er. I prefer BP over goose neck. I had a GN years ago but had problems maneuvering in and out of my driveway. I have a narrow entrance and must turn to get in or out and trailer wheels would cut corners too short curbing the wheels. With a BP the trailer wheels are further forward and due to geometry of the hitch being 4' behind the truck axle I can easily make the turn in and out of the driveway without curbing the trailer wheels.
Here's the link to mine. PJ Trailers | Powered Full Tilt (TF)
They also have GN and partial tilt with a stationary deck.
Your 2500 is probably somewhere in the 9000-10000 GVWR (as is my 2500HD) plus an 18K trailer puts you in CDL A category being over 26,000 lb. Not a problem if you have a CDL A.
/ Help me decide on a tilt deck trailer. #5
I upgraded from my 14klbs 16' tilting deck this summer. It was more or less to small fir my old L3200 much less my new L4060. I was all set on another tilting deck as they load so easily. I ended up with a 22' deckover power tilt Diamond C. The ability to load non-vehicles into it is a lot better than a gravity tilt. But it's harder to load vehicles on due to the extra deck angle. But I'm happy with it for my needs these days.
One limit for a tilting deck is width. Memory is fuzzy, but every single one I looked at was within an inch or so of i want to say 82" between fenders. That's because of tires & fenders + deck needing to stay with the legal (104"?) Width limits.Depending on length & axles/fenders impliments or wide set tires might not fit. I couldn't back my old L3200 & wide flail onto the trailer as the flail was to wide. Will be worse with M tire width & impliments.
The other limitation of a tilting deck is axle placement. On a normal trailer the axles are 2/3 or 3/4 of the way back. That gives optimal tongue weight & usable deck space. A tilting deck pivots directly between the axles, so axles are only half way back because the tilting deck needs to tilt in the middle. The last several feet of the deck become minimally usable due to balance issues, making the trailer functionally shorter than the same deck on a non-tilting deck. A fixed deck in front of the tilting deck helps mitigate some or most of that.
I've been pretty happy with my Diamond C & dont regret it at all, other than the temporary pain in my wallet. It pulls beautifully even behind my Tacoma. The F250 is a bit of a beater so I avoid it for light loads of I'll be on the road a while.
/ Help me decide on a tilt deck trailer. #6
Just an FYI that my PJ DOES NOT tilt between the axles. The pivot point is actually at the rear axle. I have torsion axles and not the standard spring mounted axles with the equalizer between them. Spring mount type axles may pivot between the axles. 16" radial tires on 8 lug rims and only an 11 degree tilt angle.
I do have a class A, but I don't drive professionally, I needed it for a job I no longer have. CA can be pretty strict, CHP are not too forgiving.
My tractors tires are 80 inches, between the fenders on these is 82", it's a tight fit, but it'll make it. :) I just loaded and unloaded my tractor on a friend's same width trailer when I had to disc that field the other day. It's not too bad. I'd rather fuss getting it centered correctly, than dealing with those heavy ramps. After just that one day, was a deciding factor on a tilt!
I think these tilt decks tilt behind the rear axle, not in the center of them like some of them do. Like you mentioned, I will also have a 6 foot stationary deck in front, to maybe allow me to use the last few feet of the trailer?
I am concerned about the rear implement, which are almost always wider than the rear tires. I do not think I would have to pull the tractor up that far though, to where the implement would be close to the fenders...?
I would like to find the center point of my tractor with loader and box blade though.
I appreciate everyone's input. Keep it coming.
/ Help me decide on a tilt deck trailer. #8
A gravity tilt makes balancing a load almost trivial. At least with my 16' center pivot tilting deck. You just drive onto the deck until it tilts. Boom, perfectly centered. Just drive forward another few inches (depending on deck length) & you get your 10-15% tongue weight.
A bit more math involved if it's not pivoting on the center of the deck or you have a fixed deck in front of the tilt. But in any case it's still way easier than a full fixed deck, or my new power tilting deck. I had to mark the deck while measuring tongue weight on a few test loads forward & backwards.
/ Help me decide on a tilt deck trailer. #9
I have the 48HDT 20' bumper pull for my L47TLB which has 72" rear tire width. Sometimes I have grapple inside loader bucket for transport to job, and that extra 400# requires tractor to be loaded 2" more to the rear for acceptable tongue weight. Had mine derated to 9990 GVRW. I also have the blackwood deck as shown, its a great option when its cold and wet. As a matter of fact I made the trip down to Aromas to get mine. I like the way 101 Trailers order from Diamond C with 12" o.c. cross members, and the 3/16" fenders. Dealing with them (I forgot the guys name) was hassle free. I had checked quality of Diamond C's build from a dealer up here, but those two features,made the drive south worth it for me. Also I welded extra d-rings forward for a better pull on the front end of tractor.
I'm wondering about what you mentioned on the fixed deck, and axle placement on the tilt trailers...What if I went longer, with a 8 foot fixed deck up front with the 16 foot tilt, for a total of 24 feet of bed length, I'd imagine that would put the axles back far enough, to give me a broader range of loading.
View attachment 548798View attachment 548799
Nice Trailer!
Brad is his name, he's been very helpful and patient. He is willing to order anything I want from Diamond C, and not just wanting to sell what is on his lot. He sells a lot of trailers.
I would for sure get extra D rings added. One thing I am unsure of is why Diamond C does not weld the D-rings closer to the ends of the trailer...They are a couple feet from the ends, as you can see in the pictures...it probably doesn't matter either way.
/ Help me decide on a tilt deck trailer. #11
Ya, there are issues with a completely tilting deck balanced in the middle. My 16' was this way. It's only saving grace was a really long tongue I could set the bucket/loader on. The tongue functioned more or less like a fixed deck up front.
I couldn't put much on the back of the deck & still get the deck to tip forward (made sure I never had negative tongue weight).
A decent fixed deck in front will mitigate most of the drawbacks from a tilting deck.
16' was too small for my 3,000lbs of L3200. I assume the trailer was made for a very heavy compact skid steer or mini-ex as it had a pair of 7k axles under it. Somehow I did manage to fit & balance a 10k+ lbs 40 year old backhoe on it. That was sketchy though. Had to remove part of the pipe rack on the F250 & no tight turns. Was only 10 miles going really slow on back roads though.
No tractor hauling photos of the new trailer, but I did haul it up the side of a 5,000' mountain on dirt roads with the Tacoma around switchbacks so tight I only had 1-2' of clearance on each side to pick up that radio tower. Pulled beautifully. Use the Taco for light jobs as its nicer to drive. The bearer F250 is used for heavier hauling. Got it after pulling the L3200 with the Tacoma a couple times.IMG_20140209_103755.jpegIMG_20140209_110007.jpeg20170315_184314.jpeg20170909_135603.jpeg20170909_182516.jpeg
/ Help me decide on a tilt deck trailer. #12
I am not patiently awaiting my Diamond C dump trailer. While not the same type of trailer, Diamond C is making huge leaps, right now. They have just finished a major multi-million dollar expansion and have a lot of features no one else offers. One of the coolest is the HD tongue box, which you can see on the bumper pulls. All that space, every other company just wastes (with few exceptions and none do a full toolbox). Plus, it adds rigidity to the whole trailer.
I ordered mine with automotive paint. They are switching to powder coat, which I do not prefer. Hopefully, mine gets painted, before they shut down the auto paint line. The order got pushed back ten days, while they moved stuff around, into the new building. If you have a preference, most of the trailers on the lot are still automotive, but some may be powder coat. After a month, or so, they will all be powder.
/ Help me decide on a tilt deck trailer. #13
Wow, I really like the automotive paint on mine. Been through that powder coat failing drill. And you are most correct about the HD tongue box, its great.
Hers a shot of the extra D-rings I welded on my 48HDT. Looks like Diamond C is doing the same with the forward rings.
Well, I think I'm going to order the 24 foot gooseneck tilt, it has the 8 foot stationary deck, and the 16 foot tilt..I hope it's not too long for other uses when I want to haul the occasional vehicle...I'm used to my 16 footer, and when I barrow my friends 20 foot trailer it feels long. Now this one would be 4 feet longer..:shocked:
/ Help me decide on a tilt deck trailer. #15
Looking forward to pics.
I don't know...if I select the 8K axle option (18k gvw) instead of the 7K (14k gvw) I lose 2 inches of width between the fenders making it 80 inches instead of 82". I just measured my tractors rear tire width...79 &1/4". That's close...real close!
Going with the 7k axles brings me back to a more acceptable 82" between the fenders...
/ Help me decide on a tilt deck trailer. #17
I have a Kraftsman gravity tilt gooseneck. 24' with a 16' tilt deck, 7K dexter axles. I love the fact that I don't have to screw around with ramps at the end of day, but I do find that the trailer is weight distribution sensitive. It is my first gooseneck so it could be a learning curve for me on how its feels compared to a bumper pull. The axles are centers 2/3 back from the front of the deck. I will send some pics this evening.
okay. looking forward to those pics. what tractor are you hauling on it?
/ Help me decide on a tilt deck trailer. #19
I had to screen shot a post I did from another forum since I no longer had the pic.
The tractor in the pic above was a MX5000 and the implement weighs 1500lbs and the load still did some chucking when going over bumps even though the rear tires were set over the center of the axles.
I now tow a L5240 Cab with loaded tires and wheel weights. I tend to bring the tractor even more forward now with the rear tires of the tractor directly on top of the front axle. I also added air bags which seemed to help. But with my limited towing with a gooseneck, my old bumper pull was a smoother tow compared to the gooseneck chucking. I still need to play around with the load distribution I guess.
/ Help me decide on a tilt deck trailer. #20
It might just be the picture, but it looks like hte board is angled inward, where the tape is. To me, it looks closer to the 80", if you had the board and the tape at a true 90*. For example, the bottom of the tape shows the board just under the 1/4" mark, the top is just over the 1/'4 inch mark. If it can be seen, at that tape width, you're quite a bit further off, at the 7, or so inches from the tape to the fattest part of the tire.
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2011 INTERNATIONAL WORKSTAR 7300 CHEMICAL BOBTAIL (A65643)
2011 INTERNATIONAL...
2017 Scag 72" Zero Turn Mower (A64194)
2017 Scag 72" Zero...
