Kubota loader options
/ Kubota loader options #1
CMV
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
Going thru the "this vs that" for a tractor upgrade - possibly. While larger machine in general has some advantages to me, I think loader capability is going to be much higher on the list than most everything else. Some of what i do is maintaining 8' tall shooting berms that I fill from behind so reach height and dump clearance are important specs. What I have now with my LS for max height/dump clearance/weight at pins:
85.7"/65"/1270 lbs
Overall have pretty much settled on L3901, HST, ind tires, and SSQA bucket is the right machine for me. I'd like more, but for specs vs budget, that's where I land. Also compared LS XR4140H but loader heights quickly ruled it out at 96.3"/63"/2713 lbs. Losing dump clearance height doesn't work for me. Have not looked at specs for all other competing brands...familiar with LS and Kubota so may be something else out there that works that I haven't researched.
Anyway, sticking point on the L3901 is the LA525 loader it gets paired with. 94.3"/76.2"/1131 lbs is an increase in overall bucket height and almost a foot more dump clearance - both would be improvements. But I struggle now with lift capacity & breakout force on a 50" bucket rated 1270 lbs at the pins, so the 1131 lbs # is scaring me. And spending more $$$ on a machine and still working around a bucket that doesn't go high enough doesn't make sense either.
I haven't gotten a quote for a 4701 yet. It gets paired with the larger LA765 loader but is otherwise overkill. I assume since the frame changes there it's a little more significant price bump than the $1800 to go from L3301 to L3901? Can I just get an L3901 with the LA765 loader? or will that only fit on the larger frame? Grand L, MX more than I'm willing to spend....by a lot.
Excuse poor drawing, but this is what i do and why dump clearance matters to me:
/ Kubota loader options #2
Are you loading dump trucks? Sounds to me like you need a bigger machine like an L47 or M62
/ Kubota loader options #3
I haven't gotten a quote for a 4701 yet. It gets paired with the larger LA765 loader but is otherwise overkill. I assume since the frame changes there it's a little more significant price bump than the $1800 to go from L3301 to L3901? Grand L, MX more than I'm willing to spend....by a lot.
An MX is only a few hundred dollars above a L4701. You get LA1065 FEL on MX and much larger wheels, especially larger in front.
Kubota Tractor Corporation - Build My Kubota
/ Kubota loader options #4
The LA525 is the only loader option for the L2501-3901, only models I know of that had multiple loader options are the Grand L.
/ Kubota loader options #7
85.7"/65"/1270 lbs
Let me summarize for my thought process:
You've got an 8' (96 inch) clearance needed.
You've got an 85" lift presently (a foot short)
You "struggle" with a 1270 lb lift capacity.
From a review of the L4701
Our test tractor was outfitted with a LA765 loader, which is rated to lift 1684 lbs to a 105.2 lift height. Dump clearance is 81.2?
From Kubota's web site:
A very basic L3901 goes for about $26.7K
A very basic L4701 goes for about $32.2K
So the price bump before any discount is about $6K.
It seems to me that if you've been able to get by with what you have an "upgrade" to the L3901 would still not give you what you need and I'm pretty sure you couldn't put the LA765 on the L4701 easily.
Go with the L4701 if you can afford it.
As an aside - How sure are you that your lift capacity is 1270 lb? Have you tested your hydraulics? Many Kubota's have been found to be significantly below spec and a few shims or turn of a screw significantly increased lift capacity. My B7610 is about 10% low. You might be able to turn a screw and increase your lift capacity.
That's not as nice as a new $30K tractor, but a lot cheaper.
Just filling those berms a few times per year....bullet strikes tend to loosen up the dirt :) No dump truck to load.
I work around now by (1) renting a large backhoe - super easy with 1.25+ cu yd bucket, unlimited lift strength, real high clearance or (2) gravel/dirt inclines behind the berms to climb up and get some elevation.
I've heard a zillion times dump clearance doesn't matter - clear the obstacle then dump over it. Problem is, I need the bucket lip right at the "wall" so the material is as far back as possible. Otherwise more just wants to run down and off the berm. I very much dislike topping off my berms by climbing an incline behind them. I feel very unsafe/awkward climbing with full bucket at max height. Although I absolutely creep doing it & haven't felt like I was just about to tip sideways, it doesn't feel "right", and I think any give out or slipping on the incline would be a wreck.
Even if the MX were only $1 more than L4701, I think 3901 to 4701 jump is around $6k. L3901 quotes is right at what I'm willing to spend. To spend any more, it makes more sense for me to let larger projects and tasks pile up then just rent a backhoe from Hertz (Herc?) 1-2 times per year and knock them all out over a long weekend. Expensive and inconvenient letting stuff pile up waiting on a machine, but $6, $7, $8k or more is a LOT of BH rentals...
So any $ into tractor upgrade definitely means no more rentals. Kind of why I figured L3901 > L3301 for $1800 more...15% more HP might be able to muscle a little more. Won't do the earth moving like a 90HP, 8 ton backhoe, but probably a lot more than my current 25HP, 1600 lbs machine. Most of my larger earth moving projects are done - or done enough that they just need finished/graded/smoothed.
This is what back of the smaller berm looks like:
Have you looked at High Dump Bucket? I think the weight might be a problem unless you find someone that makes a lightweight one. They increase your dump height by about 3 feet.
X-treme Skid Steer High Dump Bucket - By CID Attachment
Never saw one. Very interesting. @ 72" for smaller one listed there probably too big for what I have now, but could be a great option for larger machine. Still dig, back blade, and general material movement with that? Would need 3rd function remote?
I really like the +3' clearance!!!
I don't think it is. I adjusted relief set screw a little and made an improvement. Had at dealer and asked them to check because loader still did not feel strong enough and really struggled with some IBC totes with ~60 gal water or cinder blocks in bucket. Just pushing bucket down it seems all it can do just to lift front wheels off ground. But dealer looked at it twice and said it's right....
But just lbs I can lift...not a big deal for the berms. I can take a full bucket of loose dirt and lift it to max height, so strong enough for that. Where the LA525 spec concerned me is lower capacity at pins/ground level but larger bucket. I know spec sheet comparisons aren't a wonderful analysis tool...marketing guys probably write them so brand A vs Brand B spec sheets might not be apples to apples... For all I know the LA525 can easily take a heaping scoop of Carolina red clay fill dirt and lift to max height with no fuss...
/ Kubota loader options #11
CMV
Is this a range club? Any member w/ proper size tractor receives a discount if assisting w/ berm maintenance
I have a set of steel ramps , custom made w/ checkered plate when extra reach is required
There are a nubmer of folks offering high-lift buckets, HLA, Canada, pretty sure EA has them as well. A note: I have an MX, no tire ballast. Lift capacity is probably 1200 lbs w/o substantial 3 point ballast.
CMV
No, it's private - no members or other people shooting there.
Steel ramps sound like a better solution than my dirt/gravel inclines. I'm guessing that's something a lot more substantial than the ramps you drive your truck up on for a driveway oil change? Can you post a picture? I like that idea and have an acquaintance who does incredibly good welding work inexpensively.
$4k more to step up to an L4701 w/ LA765 loader and that only leaves me ~15" of height to overcome which should be doable. But the $4k probably isn't the real # going up a frame size....probably way too much for my 5' box blade, bush hog so would need to replace those too being more $. Maybe not 'have to' but if you have the tractor capacity for much larger stuff why toil with (2 sizes?) smaller?
Besides the larger engine, larger frame, a little more weight, and larger FEL, does L4701 come standard with anything else that L3901 wouldn't have?
Also - for reference - anyone trying to decide among L3301, L3901, & L4701, un-negotiated quotes with one dealer for industrial tires, HST, SSQA bucket with current Kub promotions & 0% finance is $20,5/$22,3/$26,3. Something about buying another implement (loader counts as 1) knocks some more off. Those aren't OTD #s - no insurance, tax, dealer fee, etc. Just a random reference point from here in NC. That's @ 60 months....longer terms still 0% but $600 more. I really don't understand the finance process....:)
/ Kubota loader options #14
CMV
Ramp photos, I did NOT measure, they are about 6' in length, gentle incline, 11" rise approx. Stops at top of ramp: critical!!
/ Kubota loader options #15
Have you looked at Mahindra or tym or branson , you can get more lift height and weight far less money
Don't have TYM or Branson locally that I know of. Local Mahindra, won't be back to that dealer. When I was searching for one I have now they were far less than helpful. There is another Mahindra dealer not too far...just don't know enough about their line. Worth checking into...I'm open to any brand really. Just started with LS since that's what I have and then went to Kubota since I'm familiar with them and family has long history of great luck from Kubotas since the early 80's
/ Kubota loader options #17
CMV, if time allows, visit you tube channel Outdoors with the Morgans. Videos 134 and up. These are tractor proficiency videos.
So ducked out of work a few minutes early and went to other local Mahindra dealer. Since I don't know much about them asked what would be direct comparison to L3901. Nice machines but left wondering about the "get a lot more for less money" claims I've read here about Mahindra (or LS or whoever) vs Kubota. Other than the upgraded cushy seat on the 2638 I couldn't find much that came standard on the Mahindra that wasn't on the Kubota. Ind tires, SSQA bucket - both small upcharges from Kubota were base features. Otherwise, I couldn't find anything extra. Possibly the bucket level indicator - not sure if LA525 loader has that standard.
I did note that while the seat was much nicer on the 2638, it wouldn't move back far enough (I'm average - 5'10", 31" inseam) and my leg was at 90 deg angle on the HST control pedals (literally stomping directly straight down). Didn't have that problem on the 2538 and non-upgraded seat, it went back far enough to be in comfortable operating position. I liked the loader joystick on the fender on the 2638 and felt more comfortable in that position, but all the hoses are low and exposed. I wouldn't take that machine into the woods without some sort of guard fabricated - the loader hoses look like they're begging to snag on anything. The 2538 had better routing and didn't have that problem. I liked how the machines operated and drove. Loader moved really smooth, HST brake was real nice in low gear, controls pretty intuitive and easy to reach. If the 2638 fit me better, I would definitely consider. He explained the mCRD as a benefit, but since I don't deal with burn-offs/regen now I don't know how to evaluate that as a feature.
The more for the $ part I guess is in the loader. 94.3" max/76.2" dump/1131 lbs @ pins LA525 vs the Mahindra 101" max/79.3" dump/1634 lbs. Cost wasn't all that much off from the Kubota however. I was expecting a huge difference, but $22,3 for Kubota (with tire & SSQA upgrades) vs $22,2 for the 2638 or $21,8 for the 2538. 3130 lbs weight for the Mahindra vs 2778 lbs L3901 so 350 difference there. 2 more years powertrain warranty on the Mahindra too. But since I will be borrowing ~half, the Kubota is actually cheaper overall with 0% for 5 yrs vs 6.5% for Mahindra. In all, I was quite surprised to find out for two very similar machines the Kubota actually came very competitive on price since I was expecting a "premium price" on the orange.
So...LS is out, Mahindra is out. What else should I compare? Locally have New Holland (LS in ~40HP size?), Kioti, Massey Ferguson, & JD. Possibly others but those are all I remember seeing in the area.
Have seen a few....will watch more. Thanks for ramp pics!
/ Kubota loader options #20
Based on your pic of the shooting berm, with your approach ramp in the rear of the frame that supports the berm, what about having a few loads of dirt delivered and unloaded behind the supporting frame and thereby increasing the height of the approach ramp? Actually, I would favor spending the money on a tractor with a FEL that fits your needs, but you might price out that alternative.
FWIW, about a year ago we traded in a L3800 on a MX5800. The L3800 was a great tractor. The main factor that led us to make the change was the FEL capacity--just lifting capacity, not lift height for our applications.
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
2012 Peterbilt 337 S/A 18.5ft Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2014 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2014 Caterpillar...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2017 Hino 155 16ft. Box Truck (A64556)
2017 Hino 155...
