Found an unexpected feature on my L4330
   / Found an unexpected feature on my L4330 #1
Atchuuu
Gold Member
Kubota L4330 HSTC
Purchased a used 2006 L4330 last week. Was cleaning it this morning and found the ashtray. :laughing: Reminds me of when airplanes used to have ashtrays in the arm rest.
Do the new models have a cigarette lighter and ashtray?
   / Found an unexpected feature on my L4330 #2
2012 M7040 has the lighter but no ash tray. suspect it is to allow owner to plug in fans etc.
Dave M7040
   / Found an unexpected feature on my L4330 #3
Another thing that seems to be on its way to history. Bought new vehicle recently with no ashtray or cig lighter, but plenty of "12 volt accessory outlets".
   / Found an unexpected feature on my L4330 #4
One wonders if you plugged an old style cigarette lighter into the "12v accessory outlet" if it would stand the heat, ruin the wiring, set the car on fire or what....
   / Found an unexpected feature on my L4330 #5
Should be able to withstand the heat and current. There is an industry standard for the power point as they are now normally designated.
   / Found an unexpected feature on my L4330 #6
That is a for a "power point" But does the industry standard assume only electrical flow through the connector or does it also assume a possible cig lighter with 900 degree red hot temps ?
PALLET OF PIPE CLAMPS (A50854)
PALLET OF PIPE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
