Remote control electrical outlet recommendation?
/ Remote control electrical outlet recommendation? #1
John_Mc
Elite Member
Monkton, Vermont
NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
For the past few years, I've been using a "dongle" that I plug into an outlet in my garage and is controlled by a remote control (similar to a garage door opener remote). In the winter, the preheater for my tractor gets plugged into it, so I can start it preheating without going out to the tractor. In the summer, it controls the sump pump that feeds the home-made water slide that goes into our pond.
I have yet to find one of these that works reliably. The first one I tried worked in the summer, but not in the winter, when the temperatures really dropped (obviously not what you want for a preheater outlet). The next two I tried each only lasted about 6 months, then the remote stopped working. A new battery did not help. I suspect the cheap things they use for switches in the remote just crapped out.
Does anyone have a recommendation for a remote controlled outlet that works reliably and in colder temperatures?
/ Remote control electrical outlet recommendation? #2
How many watts does your block heater draw? I assume that your sump pump doesn't draw much current.
Aaron Z
/ Remote control electrical outlet recommendation? #3
John I use a timer for my diesel pickup, now it's not remote controlled and will do the same "thing" every 24 hrs., but with just a little planning the evening before……..
Iirc both Lowes & HD have one that's good up to about 2000 watts for well under $40, but still looks like a lamp timer so read the package first.
Then Lutron has a line called "Casetta" (not sure on the spelling) that will control an outlet remotely but I've only used it for lighting and I don't know it's wattage rating, also at Lowes.
/ Remote control electrical outlet recommendation? #4
after searching the word "dongle" I am still not sure what one is and if it is treatable
/ Remote control electrical outlet recommendation? #5
The big two systems are Zigbee and Z-Wave. Both WIFI type systems but interesting because each device acts as a repeater. Everything is available for these systems, doorlocks, stats, alarm stuff and all manner of electrical stuff, Of course, all able to be run from your smart phone.
/ Remote control electrical outlet recommendation? #6
It's a computer term. Probably a misuse of the term. On a computer it's just a little gizmo that you plug into a computers USB port (or other port). A "WiFi Dongle" plugs in and gives you WiFi capability. Some use it to refer generally to an adapter: a dongle to adapt my 240V outlet to the plug on the end of my welder.
Can't use a WiFi based system in my application. My signal does not reach, and I'm not really interested in extending it.
/ Remote control electrical outlet recommendation? #9
It would work if you had other devices in between acting as a repeater. It does not run on your wifi, but is it's own wifi.
/ Remote control electrical outlet recommendation? #10
Years ago I used a remote switch made by Heath Company. Had a range of 50 or so feet, can稚 remember how much wattage it could handle. Remote looked like a wall switch and used a 9 volt battery for power.
/ Remote control electrical outlet recommendation? #11
I have about a dozen of those Heath units laying around that I bought at the Re-Store . They are good for about twenty feet it seems which is why they were all Home Depot Returns. I once tried for the 200 feet line of sight from house to garage and no way!
/ Remote control electrical outlet recommendation? #12
Like I said years ago. I do remember that it was sensitive to battery condition. I was changing batteries more than I should have for something that was rarely used.
/ Remote control electrical outlet recommendation? #13
John
After trying anything affordable and further, after getting the acknowledgement from one manufacturer that his system could not work in the cold, I opted for two different types of systems over many years. My tractor shed is 300 feet from my home
Having a real 110 volt relay with a coil, often 24 volts AC, but also possible with 12 volt DC is the reliable way to switch power on or off when very cold.
The remotes on the market use electronic components instead of simple points to do the on off switching.
If you plug a low wattage led bulb into the remote's receptacle, it will usually glow even though switched off because some current is bleeding through.
My simple solution was been to run two wire lamp cord over the ground from my tractor shed to my home. A 24 volt transformer and a switch and you control the relay.
Removing the wire in the spring is an inconvenience but must be done for grass cutting and because the sun will destroy the cheap lamp cord insulation.
Later, I ran a shallow buried water line to serve as a conduit so the control wire could remain in place all year.
Automotive remote car starters are cheap and have reasonable ranges. They are designed to work in cold weather.
With a little ingenuity you can have one switching any remote relay on or off.
There are systems on the market which control locomotives in train yards, boom trucks while standing back from the truck. Th technology is available it is the price that keeps the average person from using them.
Dave M7040
/ Remote control electrical outlet recommendation? #15
i have figured out how i like to feed my cows in the winter every morning. i like 9am. i have a timer that i plug my block heater into and set it to come on at 7am and goes off at 10am. tractor starts quickly and warms me up quickly also. gives me plenty of time to get my feeding done. if i get back before 10 i just plug the heater back in and turn the timer off and it will come back on at 7am the next day and warm my tractor up again.
/ Remote control electrical outlet recommendation? #16
I also just have mine on a timer. It's plugged into an inside outlet in the garage building next to where I park the tractor. Have mine set to come on at midnight (or 2am, I forget), and goes off at 8am. That way if I'm up early to clear snow on a weekday, it's warm, and if I'm sleeping late on a weekend and have to clear snow, it's still warm. I wish it had separate days of the week for programming off and on times, but this works fine. It's an outside "rated" timer, and it wasn't very expensive.
/ Remote control electrical outlet recommendation? #17
My Liftmaster garage door opener has the option for a remote switch. The middle button on my remote operates it. I think (but never used it) that the WiFi unit could operate it as well. I use it to turn on a light in the house and one upstairs in the unheated garage. When we come home at night I can turn them on from several hundred feet away. The light on the opener just lights up inside the garage until the door is opened so being able to turn the lights on as I'm getting close ot the house is nice. It's good for up to 300 watts so it might be able to operate the block heater directly. If not it would be easy to install a contactor that the switch operated which in turn would turn on an outlet rated for as much power as you wanted. Can you use a remote to open your garage door from in your house?
/ Remote control electrical outlet recommendation? #18
This is what I use to plug my blocker heater in. It's about 150' from the house to the tractor. Buy Switch Remote D/collectors11v 15amp at Busy Bee Tools
I was very interested in the Busy Bee device. It is double or triple the cost of other remotes so it perhaps is more industrial than the others.
I wrote to them asking about their product's ability to operate at -15C.
Their reply:
Dear David
Thank you for your email.
Unfortunately we don't have any data of that sort for this, as this item is generally used indoors.
We appreciate your interest in our products.
Robin
Customer Service,
Tel: 905-738-5115
If I was going to buy one to use in the winter outdoors, I would buy it now, try it after some hours in the freezer.
If it works great. If not you do not find out on a cold night when you are counting on it. Just return to Busy Bee.
Dave M7040
John Deere 1518 (A64126)
John Deere 1518...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
New Westinghouse Generator (A62613)
New Westinghouse...
24in pin on excavator tooth bucket (A61307)
24in pin on...
