Replacing seal in gearbox
   / Replacing seal in gearbox #1
AlbertC
Perry, GA
New holland 3930
My bushog is leaking oil where the pto shaft goes into the gearbox. Is this a difficult repair to make? I assume it is some kind of seal but the bushog has had a pretty easy life. It is only about 5-6 years old with about 300 hours on it used almost exclusively for cutting grass.
Thanks
   / Replacing seal in gearbox #2
I have do mine - its made by woods the center bolt that goes up into the gear box had a spot weld that had to be ground off. when you get a new seal they also sell new washer that is curved and pounds in so you don't have to weld it . you will also need a gear puller .
should go without saying but I will say it do not just rely on the 3 point to hold it up - put jackstands under the deck
   / Replacing seal in gearbox #3
There's another option: I have an old post hole auger that was leaking from the same spot. I replaced the oil with Corn Head Grease. It's thick enough that it stays put, but coats the gears well when they get moving. No leaks!
   / Replacing seal in gearbox #4
Thanks
Not a hard job because you are not afraid of damaging the old seal.
Buy a new seal first, made for your model. Later you can switch to lower priced seals but for the first time you want one that is exact.
From that new seal you can take measurements or go to a bearing supply place and have them find an equivalent seal for the next time.
Post a couple of photos. I expect a flat screw driver and a hammer will enable to to get the seal out of its recess.
In my experience, it is wise to use gear oils with extreme pressure additives. Most auto parts places have such products as they are required in differential axle gears.
The EP additive increases the cost very slightly.
The "fill it with grease", is certainly an old farmer's trick. Wonder why, if it is such a good idea, gearbox manufacturers like COMER do not use grease.
Before condemning the seal, make certain the gear box has not been over filled and check carefully to see if a tiny vent is present and if so open.
Rainwater getting in to the gearbox will raise fluid levels and cause over pressures and leaks. Outside storage is best avoided for long life.
Is the pto shaft the correct length? Too long and extreme pressures happen when the hog is raised at the point where the pto shaft is horizontal.
Youtube has many videos on pto shafts.
Dave M7040
   / Replacing seal in gearbox #5
Dave: I get your point on the corn head grease, and I guess in this application I'll retract my suggestion. In a 20 year old PHD, I stand by the idea and have no plans to pull the gear box apart. But in a much newer brush hog... better get the seal.
   / Replacing seal in gearbox #6
Along with what has been suggested, check the bearings while you have it apart. A bad bearing can cause a seal to start leaking.
   / Replacing seal in gearbox #7
If I am reading this correctly its the input shaft that leaking and most gear boxes have a plate that the seal is in so no need to disassemble the box , Its a 10min repair .
Yes it is the input shaft from the pto. I have cleaned the vent plug and am going to clean the oil off the frame to see if it could have been leaking as the result of o clogged vent, but I am thinking that this was probably not the cause.
If it is still leaking, does it take any special tools to replace this seal? It is a Bushog brand 286.
Thanks
   / Replacing seal in gearbox #9
Thanks
See post #4
Easy job.
Drive screwdriver blade between outer edge of seal and housing and pry it out.
To replace, oil the seal lips, gently tap around the seal circumference in a uniform pattern until it is seated.
Check oil level.
Done
Dave M7040
   / Replacing seal in gearbox #10
no special tools. without seeing the face plate i would guess its just a 1/2" bolts holding the seal and bearing in place.
LaneShark LS3 (A56469)
(10) 24' CORRAL PANELS W/ (1) 12' GATE (A57192)
(10) 24' CORRAL...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
Ez-Go Electric Cart (A55853)
Ez-Go Electric...
2007 STERLING A9500 DAY CAB (A57880)
2007 STERLING...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
