Buying Advice Kubota Mower decks
/ Kubota Mower decks #1
isenbed
Member
Clinton TN
Mahindra 26xl, Kubota BX2660, New Holland TZ24DA
Does anyone know if there is a difference between the B and BX mower decks? I found a used RCK54-29B mower and was wondering if it would fit or could be modified to fit my BX2660.
Thanks
/ Kubota Mower decks #2
I'm not familiar with the BX decks, but I would guess that they are not compatible without some major changes. Probably the lift points in the middle of the deck are farther apart than the BX. Also the front lift mechanism may be different, and the location of the PTO shaft is probably different. A rear finish mower would probably fit much better.
Joe
/ Kubota Mower decks #3
You could make it fit but I wouldn't! On that size tractor they work very well with a 60". I wouldn't convert it if it was free!
/ Kubota Mower decks #4
Thanks
B series MMM decks are totally different from BX decks.
Among other things, BX decks are suspended, whereas B series decks are terrain following.
SDT
Thanks, that’s what I needed to know
/ Kubota Mower decks #11
Yes and they are not comparable to the B decks, just saying.
I didn’t suggest the B/ BX decks were similar or interchangeable. My point addressed your statement that BX decks were not drive over style, which is only partially accurate. Some are, some are not. A BX deck with a ‘D’ in the model designation is a drive over deck.
/ Kubota Mower decks #12
FWIW, folks, I did buy the B3350 a couple of days ago, but after inspecting both 60" and 72" B series MMM decks, decided against a MMM. Rather I bought the FEL and the QH10 quick hitch in order to get the two implement incentive. I do not use quick hitches so my dealer let be trade it back in in the same transaction.
Currently, I mow my grass with an absolutely WONDERFUL B1750HST/Bi-Speed Turn and 60" MMM bought new in 1994. This is a GREAT MMM.
Though the lineage of my 1994 deck can be seen in both the 60" and 72" current model B series decks, they have been cost reduced so many times that I am now skeptical.
I like the 4 castering gage wheels on the 72" deck but do not like the half-yoke (L bracket) gage wheel supports as I believe these will have long-term durability issues. My 1994 deck has full yoke caster wheel supports. Kubota has also removed the center front and center rear anti scalpe rollers that my 1994 deck has.
The 60" deck has castering gage wheels on the front only. It has two center mounted gage wheels on the rear and a decent anti-scalp roller on the right rear but a totally inadequate anti scalp wheel on the left rear. More troubling, the dual rear center gage wheels do not caster. I R & R my current MMM each spring and fall. To do so, I drive the tractor onto a couple of layers of 2X6 to gain clearance and roll the deck in/out from the side on a concrete floor. Yes, my deck is called a drive over but my way is actually quicker and easier. BTDT. I can envision no easy way of R & Ring the current B series 60" deck (not a drive over) without castering gage wheels. Anyone have a better idea?
SDT
/ Kubota Mower decks #13
Not much to add, but to say I don't think these changes are made for cost reasons. It's likely that todays tire options are causing clearance issues with the back corners of the mower decks. There are models you can't use some deck\tire combo's with and I'd suspect they are addressing clearance issues with the design changes.
/ Kubota Mower decks #14
Well aware of tire clearance issues with terrain following MMM decks but I can think of no reasons aside from cost to change from yoke style to single-sided L style wheel brackets on the 72" model (which does still have 4 corner mounted gage wheels) while at the same time removing both center mounted anti scalp rollers.
Regarding the 60" model, the structure supporting the front 2 gage wheels is much less substantial than that on my 1994 deck. Again, I question long term durability.
SDT
Mini Skid Steer/ Excavator Tracks (A61570)
Mini Skid Steer/...
UNUSED WOLVERINE MCB-11-48W 48" MINI HYD 4IN1 BKT (A62131)
UNUSED WOLVERINE...
Dewalt 60 Gallon Air Compressor (A61166)
Dewalt 60 Gallon...
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
2016 Ford Fusion AWD Sedan (A61569)
2016 Ford Fusion...
