What have you done to your Branson today?
   / What have you done to your Branson today? #221
I had a D-ring welded on the top center and a couple of weld on hooks on either side on the top lip of my bucket years ago. One of the best mods anyone can do.
Amen! I don't know what I would do without my hooks and clevises. Thinking about welding on another set of hooks pointing backward so I can lift behind the bucket instead of always over the lip.
   / What have you done to your Branson today? #223
What's the going rate for dead cow burying these days?
One way travel time and whatever it takes to dig the hole, push the animal in it and backfill. My rate is $60 an hour.
   / What have you done to your Branson today? #224
How much is the going rate for bush hog or finish mower work
   / What have you done to your Branson today? #225
Mine got unloaded from delivery. I also replaced the bad 3 point arm, the prior owner damaged or lost it and had put a piece of channel iron on to lift the 3 pt. :confused::shocked: I ran it a small amount with a blade and am getting ready to do all the regular maintenance since I don’t know it’s history.
It was a repo at a bank and I got it for a steal.
   / What have you done to your Branson today? #226
Nice.
Good idea to do all fluids and maintenance. A guy that can't keep up the payments, probably wasn't keeping up the maintenance either.
Post some pics of the new tractor.
We like tractor pics.
   / What have you done to your Branson today? #227
As requested. My wife had to try it on.
   / What have you done to your Branson today? #228
Uh oh. You better watch out, she may decide that it's "her tractor" and you have to get your own!
:D
   / What have you done to your Branson today? #229
I got up at 6 AM today and laid out the chains and straps and 6000 pound come along. Dug the mud from behind the rear tires and started cranking. After about 30 minutes, I had cranked it back to solid ground and was sitting at my desk at work by 930. It was almost fun pulling it out. Almost.
If it was that much fun.. Go bury it again and take pictures and post them up..
IMG_20161026_130535782.jpg Mine got a little stuck, so I used my Jeep and winch to extract it.
   / What have you done to your Branson today? #230
Thanks! It really seemed to help the traction and back end "float" when carrying dirt. I should clarify that the fluid was on clearance. I picked up a drill powered pump and fill valve at TSC. Worked like a champ!
That was the first modification I did to mine when I bought it. Too it to Les Schwab and had them fill the rear tires with antifreeze and water mix. They are 3/4 filled extra weight for traction and heavy loads in the front loader. So worth it.
22018 (A56859)
22018 (A56859)
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
