Shop press
/ Shop press #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Harbor Frt has a 12 ton press on sale for $99. Is this press strong enough to straighten a kink in a 1" round bar tie rod?
/ Shop press #2
The 12 ton is a death trap! The frame flexes long before the ram runs out of steam. The resulting equal and opposite reaction is violent- I cut mine up so I would be tempted to use it again!!! Their 20-30 ton (sorry I don’t remember which) has a cult following and several folks make aftermarket parts for them. Save up a bit a spring for that one!
/ Shop press #3
If its not too sharp a kink. A sharp kink will require a close span setup initially to prevent rotation as force is applied. A close span takes a LOT of force. With 12T on 1"dia You probably wouldnt be able to move the metal on a span closer than ~6"
/ Shop press
That's enough for me not to acquire it.
Thanks RN and Spydy
/ Shop press #5
To be clear I now have the HF 20 or 30 ton model and find it works well for a home shop. If you can keep the tie rod from rolling I believe it will straighten things up.
/ Shop press #6
I have the 20 ton and am happy with it.
I added extensions to the legs so I didn't have to get on my knees to use it.
I also upgraded to the 20 ton air over hydraulic jack and really like it.
I can still use the handle for fine pressure or air for regular.
To keep rod from kinking or rolling set in on blocks of wood and push with block on ram.
/ Shop press #7
I copied much of the design of the HF 20 ton press and built my own using side pieces identical to the HF 20 ton and some I beam i had laying around.
While back, bent one of my grapples 1 3/8" round tines. so i decided to try and straighten it with the press and some heat from an oxy/acetylene
anyway ended up snapping the tine
no damage to the press, - My guess is the HF 20 ton will work for you
/ Shop press #8
I have the 20T. Works great for me, as a home shop light duty press. It does have it's limitations, and I'd never consider it for a professional production shop, but it has worked for me on several jobs around the shop. For a 1" rod, I'd think it would straighten it, if you can set up your bend properly and keep it from rotating first. May have to do it in several steps to get it done.
/ Shop press #9
I have a 20 ton and have straighten 1" stock or bent it, I use my press a lot, a 20 ton can send things flying so use with care and caution, wear eye protection,
/ Shop press #10
Do you own a logsplitter? I use mine for pressing things all the time. Got a piece made to slip over the wedge and protect its edge (and to not cut into the steel Im pressing)
/ Shop press #11
Smart!
/ Shop press #12
The style of my first picture is a death trap when it comes to press design. This design is also fixing to be outlawed in the shop's for the company I work for.
The support tubes next to the springs are a week link. Which I can attest to since I killed ours with a torch after it tried to kill me. :eek: Thankfully when the arms bent and it spit the shaft out, it went the opposite direction And tried putting the shaft through the wall instead. It dented the siding and shook the building when it hit the wall. Not to mention the bang, which got everyone inside the building into the shop to find out what happened :eek:
Second pic shows what we switched too. Granted it's $100 more, but money well spent. Actually getting spoiled since it's air over hydraulic. Nicest feature is you can stand off to the side if you have something being really stubborn. :thumbsup:
/ Shop press #13
I might have to fab something up and give it a try. Wife's been after me to replace the frame on one of our metal frame benches that has started to disintegrate.
/ Shop press #14
I have the 20 ton HF press. One of the cast plates broke in half. I went to a fab shop and had some cut out of steel instead of the HF cast ones
ARBOR PRESS PLATES I didn't pay near this much for having mine made from local shop
/ Shop press #15
I do the same thing - I haven't had the need for a dedicated press so I built a slip over for my splitter and it works okay for some gross work - kind of tricky to do delicate pressing though.
/ Shop press #16
Still use my splitter for pressing- in addition to the new press.
about a week ago decided to straighten a bumper pull utility trailer's axle that I built out of an old boat trailer.
It was much easier to use the log splitter with add on push plate and a rail road rail for the axle to sit against for pressing the bend out of it caused by PO using the axle as a (jack) point.
The log splitters work great -but a deft hand is needed due to the hydraulics being under engine power.
It can be easy to (overdue) it in just a second -even feathering the spool valve :D
/ Shop press #17
Here is a pic of the press plate I made for mine, if I were to do it over a larger area for the flat surface would probably have been a good idea but used what was around at the time.
View attachment 547855 View attachment 547856
Sure some of the other posters have some great ideas for a pusher plate to for Dftodd
Actually I like your set up. I do agree with you that the plate needs to have more flat surface.
I probably got enough scrap pieces in the garage to make one up. Plug one with a V to make my bends. Either way, I got some ideas on a new project :thumbsup:
/ Shop press #18
When working on old equipment like backhoes.....a logsplitter with adapter plates is a good tool to have for pins and bushings. And its already oriented the right direction:thumbsup:
/ Shop press #19
Good post.
/ Shop press #20
How did the guide tubes fail?
My HF 20T press has served me well, tho I do not have the air-over-hyd setup. I bought it over 10y ago for
less than $200, and I have maxxed it out numerous times. It is orange and the guides are nothing like
in your left photo. Sometimes I wish I bought the 35T or 50T unit.
I do like my standalone 20T jack with air control, also from HF, so it makes sense that air control
on the press is a good thing.
