terryknight
but everything for the bucket has arrived as of this afternoon, so tomorrow i will probably do that and then bring it home, or maybe wed. pics to follow that
Your wife do the welding? Tell her great job ! She’s handy to have around. I have to do all the welding at my place
LOL, yes a 700 lb Grapple wouldn't leave you much lifting force at all to do any work. I'm planning to go one of 2 ways, EA grapple that is around 300 lbs as a first choice, or one of the grapple as on deals that installs to your bucket. The second choice is around 300 lbs on top of the weight of your factory 60" bucket, but can be done for $900-ish versus the EA grapple for around $1800.
I was thinking maybe going with pallet forks and grapple? I have lots of brush to clean up and started to do some logging by the house so bucket isn't very useful moving large logs around. Although with the new chains and spacers I was able to pull some large green logs out into the field. ��
Picked up my new B2650 at end of August with a mid-mount mower deck. Still don't have the FEL mounted, but hope the dealer will get it all together by mid November. I primarily used it for mowing the acreage. It mows really well. I haven't removed the deck yet for the winter, which has always been my norm for the last 30 years with my old Boomer. It will take a little while to make it mine. I have removed the tiny tool box and replaced it with a 50cal. Ammo box. the factory box would hold a pair of gloves, and a few small little items, not near enough space for the minimal amount of things one should carry out onto the property.
Just picked up a B2650 today. Open station, FEL, SSQA, 60" bucket, Turf tires, One rear remote, quick hitch. Bought it from Burke Equipment in DE for 18600. I thought this was a pretty good deal. I was looking to replace John Deere 750 2wd, gear, no loader, no power steering, without go larger in size, I was also looking for a bit more HP.
This will be a thread for everyone to see what life with a small compact is like, or at least mine. I will post what I do with it and when I do them, both for the knowledge of the forum and it may help me remember when/how I did things.
Picked it up today around noon with .5 hrs, brought it out to the farm to pick up the rake, dad asked me rake the lane did that, then brought it home. tomorrow rake my driveway swap to the rear mount mower and then take the JD back to town. We're upto 1.3 hours now.
Need to do a couple things add hooks and 2" receiver to the bucket, receiver will require a bit of fabrication. I would like to widen the front track, don't know if I can flip the front wheels to do that or not. I will find out. The remote is kinda ugly looking, but I haven't found a way to make it better looking/protected. However it does give e nice place to lean against.
Pics to come tomorrow when it's not dark.
Can Kubota front weights be attached to the grill guard? If so, how many?
If not, can the front weight bracket be mounted simultaneously with the grill guard or must the grill guard be removed to mount the weight bracket?
Not to hi jack the thread.. but you guys with 2650s what position is the front grill guard mounted? Mine is mounted way out in front of the tractor but it looks like there is another set of holes so it could be mounted a little closer.
