FEL bucket not staying up
/ FEL bucket not staying up
Well...put new seal kits on today. Started the tractor and immediately it went to the dump mode !!! I didn't have the bucket hooked up. So I pulled the piston rods out to check if maybe I tore a seal when putting it in. All seals good. Scratching my head now...ugh ! Not sure what the problem is....maybe somehow there is some seals missing I didn't account for ? So will look at the parts diagram and make sure I can account for all the seals.Is there a certain madness in the sequence of how you put the piston in ? Like...do you have the piston all the way out or in when you put pressure on ? Any help would be appreciated....will start over in the morning !!
/ FEL bucket not staying up #42
When you start the tractor unless you move the loader valve nothing should happen unless the valve is leaking by
I didn't touch the joystick. This ran through my mind. So maybe one of the spools is stuck open to dump. Guess I could tap the valve and see if it frees itself up.
/ FEL bucket not staying up #44
If you take the dump and curl quick connect off and put a gauge on it, If its leaking it will have pressure
/ FEL bucket not staying up #45
Your cylinders are full of air which is compressible. Hook up the hydraulic lines and cycle the bucket back and forth from full dump to full curl six or eight times. That should purge the air out and leave you with just hydraulic fluid in the lines.
Aaron Z
So I need to get a pressure gauge ( thats one tool I don't have ! ) and put a quick disconnect fitting on it so I can hook it up to the hyd line ?
/ FEL bucket not staying up #47
Kenny's bolt on hooks a member here on TBN sells them a gauge setup
Aaron Z
I thought the same thing....did it numerous times with no help. Going to order me a hyd pressure gauge kit !
/ FEL bucket not staying up #50
I don't know kenny will hook you up with the correct kit
/ FEL bucket not staying up #53
A related question since there are so many knowledgeable folks here. I've always pushed my loader to float when parking it. The other day I left it up and came back not much longer and it was down. Tractor only has 70 hours on it. Any chance it's intended to be that way?
/ FEL bucket not staying up #54
I don't think it would be intended for a loader to leak down, but it's not that big of a deal either if it occurs over several hours or more
/ FEL bucket not staying up #55
To all the contributors:
Thanks for all those tidbits of info on how the FEL works and the 'whys' of how probably many of us (well me for sure) unknowingly abuse our buckets.
So no more back dragging past those ten degrees.
Many videos provide do's and don't, but this platform also shares the why's.
Although at times it is a easter egg hunt, the trip is quite informative and at times entertaining as well.....
keep us up dated !
Glad you found the problem.
Lots of good info and some not so good in this thread so I'll offer my :2cents: just for future viewers.
1. No a cylinder cannot retract with faulty seals.
2. Retracting causing "drift" is usually associated with the main loader lift.
3. YES a cylinder can extend if seals are faulty.
4. Extending "drift" is usually associated with bucket cylinders or backhoe booms.
And a faulty valve leaking by internally can cause drift of any kind.
Hands down the easiest way to isolate the cylinder from the valve.....if in doubt.....is to uncouple the quick disconnects that most modern tractors are equipped with. But a word of caution is that it puts the fluid under pressure and makes it difficult to re-seat. So the method I like for testing curl cylinders is as follows....
1. Put bucket on ground.....level or slightly dumped......and disconnect curl hose QD's.
2. Raise loader in air and moniter if the bucket drifts further towards dumped position. If it does....cylinders faulty. If it doesnt....valve faulty.
3. Lower bucket back to ground to take pressure off couplers.
4. reconnect couplers
LD1...you are the winner ! Put it all back together today. With pressure on the 'dump' coupler it immediately went to the dump mode. Bled pressure off and disconnected the 'dump' QD. Started tractor and with no pressure on the 'dump' coupler the bucket did not move !!!
Following LD1 advice it seems I have a bad ( dump ) loader valve. As most of you have suffered sometimes another problem arises that happened at the same time your original problem arose !! I can't think of anything else that would cause this other than a bad loader valve. So I will look up the price of a new valve.
Got off the phone with the kioti dealer. He said to take out the 2 spool valves first and clean them good and that maybe there is a blown seal. The loader valve is $1300 ! I will start with the simple stuff first !!!
/ FEL bucket not staying up #59
$1300 ouch your right simple stuff first
/ FEL bucket not staying up #60
Ouch.
Aaron Z
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
213088 (A64276)
213088 (A64276)
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2014 F-150 4WD (A63689)
2014 F-150 4WD...
EZ-Go Golf Cart (A65579)
EZ-Go Golf Cart...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
