Check Engine code P1804 - Mahindra 3550 PST
/ Check Engine code P1804 - Mahindra 3550 PST #1
MatHaas
Grantville, PA
2016 Mahindra 3550 PST
Does anyone happen to know what the Check Engine code P1804 specifically means?
I've seen it mentioned in another thread that it was a Mahindra specific code but no description was given of what it means.
Tractor had 1st issue of cranking but not firing. Tried it a second time and it fired. Check engine light came on briefly but then went away in 2 minutes before able to check it.
Then 2-3 episodes of the tractor failing to fire when cranking 3-4 times and would only fire when throttle is held wide open. Check engine light stays on and it's now in Limp Mode, not revving past 1900 RPM. OBD2 reader says code P1804.
Waiting to hear from the dealer.
Just thought i'd ask here.
Seems fuel related.
Tractor was running great, first time it saw below 1/2 tank of fuel and this started happening now, increasingly worse.
Pulled the tank and checked the screen/pick up, clean as a whistle.
No water in fuel; pre-filter drain check looks good.
Filled the tank back to full just to check, but it's still cranks and needs full throttle to fire.
Thanks.
-Haas
/ Check Engine code P1804 - Mahindra 3550 PST #2
2017 Mahindra 3550 PST
Seems fuel related.
Thanks.
-Haas
Sure it's an 1804 and not 1801?
yea, P1804 (disregard the 1/2; it showed P1804 as both codes)
/ Check Engine code P1804 - Mahindra 3550 PST #4
P1804-- RAIL PRESSURE LIMITER OPEN :eek:
Just heard from the dealer. This was a "left over" tractor from a dealer that got bought out. Per the dealer, the service bulletin for the the ECU reflash was never performed on this tractor. So that is their plan, to come by later this week when I'm free and do the reflash / updates.
From browsing other posts, that seems to be the first step for a ton of issues, ECU reflash.
Lets hope that works.
If not, it probably some other sensor or electrical issue, as seems to be the trend with these tractors.
Guess we'll see.
LOL, you look more worried than I am :p
I think I might recall reading somewhere about high pressure on the rail causing a fault.
I'll post an update then.
Thanks for the info sir.
Also, just curious, where were you able to find that info? Would be helpful to have a reference.
Thanks!
Well if you haven't seen my other thread yet, I'll just follow up in here since this thread is tagged specific to the P1804 code.
You can follow this link for a thorough mahindra CRD diagnostic manual pdf: http://kisandost.com/KisanMitraWeb/MarketBulletinView?moduleType=SubjectPartFile&FileName=203
pdf page 330
P1804 - RAIL PRESSURE LIMITING VALVE OPENED
Possible Causes
• Loose connections
• Wiring harness problem
• Metering unit pump failure
• Rail pressure sensor failure
DTC Information
-Lamp Status
The Check engine (CHK ENG) lamp in the instrument cluster blinks continuously.
- DTC Reaction
Rail line needs to be changed after 50 counters.
Follow the PDF for the Step by Step diagnostic procedure.
-Haas
Well here is update after the Dealer came out today.
I will first start off by saying that so far, I've had great support from my dealer.
I purchased this tractor new from PowerPro Equipment in Lebanon, PA.
The sales manager has been extremely responsive, ensuring they will take care of everything in a timely manner and at my convenience. He's assured that even prior to purchasing, so I want to definitely give him credit. And he drove up today with the Technician for them to hook up the tractor and see what's going on.
They hooked up the Garuda software.
They tractor was showing an active code "P0340 Camshaft Sensor no signal"
here is from the diagnostic manual:
"P0340 - CAMSHAFT NO SIGNAL
The Camshaft position sensor senses the Top dead center (TDC) point of the
first cylinder in the compression stroke. This allows the ECU to determine when
to start the injection.
Sensor records the rate at which the camshaft is spinning and this information is
used by the ECU to control ignition and fuel injection.
Possible Causes
Loose connections
Incorrect fitment of camshaft position sensor
Excess gap between sensor and cam gear
Faulty camshaft position sensor
Faulty ECU
Normal Operation
At normal vehicle condition, the ECU receives an output voltage signal (5Volts PWM Waveform) from the camshaft
position sensor.
DTC Detecting Condition
Normal waveform pattern has not been input for cylinder identification from the camshaft position sensor signal for
4 sec. (Engine should be cranked to check this error).
DTC Reaction
Delayed engine start.
Engine speed limitations.
Engine may stall while driving.
Lamp Status
The check engine (CHK ENG) lamp in the instrument cluster glows."
So they're ordering a new Camshaft Position Sensor.
For clarification, the Camshaft Position Sensory / Crankshaft Position Sensor / Engine Speed Sensor are all synonymous on this tractor. There is a single sensory on the front of the engine, between the alternator and crank pulley.
The symptom descriptions from the manual does match my description of issues.
Make note, my OBD2 reader said code P1804 Fuel Rail Limiter Valve Open, which did NOT appear on the Garuda factory software. So maybe generic OBD2 readers can't be trusted and you'll have to have a dealer tech plug it in for you unfortunately.
So the plan is to swap in a CPS and see how it does. They also installed the most current ECU software they had, aka the ECU reflash. I did mention about the temp gauge not moving at all unless I was actually doing some serious work with weight on the tractor. I also saw a video where someone explained how when Mahindra switched to the newest Tier 4 powerplant they never utilized the proper new temperature sending unit/gauge combo.
The Tech is going to see if he can find more info on this and track me down an appropriate temp sending unit if possible.
Anyway, i'll keep this thread updated when I have info.
-Haas
Here is a pic of the sensor; front right of the engine. in the middle of the triangle formed by the alternator pulley, fan pulley, and crank pulley.
The wiring tag says Segment Speed Sensor. The Mahindra Parts manual say Phase Sensor. The Garuda software read the code as Camshaft Position Sensor. It could also be Engine Speed Sensor or Crankshaft Position Sensor.
I figured I'd update this so it has an ending.
One correction to what i said in an earlier post: "For clarification, the Camshaft Position Sensory / Crankshaft Position Sensor / Engine Speed Sensor are all synonymous on this tractor. There is a single sensory on the front of the engine, between the alternator and crank pulley." THAT IS NOT FULLY ACCURATE
There is a separate Crankshaft Position Sensor located on the right hand side of the bell housing, just under the cab (essentially under the brake pedal). The tractor had no input from the Camshaft Position Sensor / Segment Speed Sensor (as per the harness tag), so it could only go off of the crankshaft speed sensor to communicate to the ECU about engine position. The ECU automatically limits engine speed to around 1900-2000 RPMs and the CHK ENG light comes up on the dash, showing code P0340 on the Garuda software.
So anyway, I finally had time to arrange for them to come up. Again, the dealer is just great, and sent the tech up to my house this morning when I was free.
I already had the sensor ready for replacement.
I raised the loader to max height. Locked the hydraulic joystick. Opened the hood. Removed the two 12mm bolts to hold the exhaust pipe on. And then had semi ok access (for my relatively small hands) to the sensor. I removed the harness clip. Then used a 5mm allen wrench to remove the single sensor bolt (note, the screw head had some paint or rust in it at first and I could only get a 3/16" allen in it but it was loose. A little wobbling around and I got the proper 5mm allen in there and removed the bolt).
Theres a rubber oring around the sensor. If it's not on there, be sure to fetch it from the hole in the block were you removed the sensor.
New Bosch Sensor P/N 0 281 002 667 was installed.
Clip placed back on.
Exhaust pipe reinstalled.
Turned on the key, let the grid heater run.
And she fired immediately upon cranking.
CHK ENG light gone.
Hooked up the Garuda software, P0340 code showed as healed, and we cleared it out afterward so the ECU is clean.
I'll also say that the temp gauge now responds appropriately after the reflash they performed on the initial visit also. Atleast it seems that way. it's also been 20-30 degrees warmer now though too.
Anyway, that's a wrap.
If you're located anywhere near Lebanon, PA; I highly recommend Power Pro Equipment in Lebanon for any of your needs. They're great people. Mel the sales manager, Matt the technician, and Lucas the parts guy were all great since I started dealing with them.
And the statement holds true, your warranty is only as good as the dealer who fulfills it. (Power Pro Equipment in New Holland was also very helpful when I first started looking).
I put this beast to work yesterday anyway even with only 1900 RPM limit. It digs like I hoped a 10,000 lbs tractor would. So happy with this purchase so far.
-Haas
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2026 Electric Tricycle (A64194)
2026 Electric...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
