Mystery Part
/ Mystery Part #1
alexsbuddy
Gold Member
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
Found a small black rubber part, approx. 2" tall by 1.5" wide, on the trail that I drive my tractor on a lot. Figured it might be from my tractor, but darned I can figure it out. Thought I would post some pictures of it and see if anyone knows what it is and where it goes. What do you think it is? 20180401_150633.jpg20180401_150600.jpg20180401_150507.jpg
/ Mystery Part #2
It goes on the air filter canister
/ Mystery Part #3
/ Mystery Part
That was my first thought, but it's the wrong size and mine is intact. I think it must be some type of cap that allows moisture to drain if necessary. It is soft rubber and is flexible.
/ Mystery Part #5
Looks like part for flush meter vacuum breaker :confused: but that's plumbing.
/ Mystery Part #6
Off somebody elses tractor, Maybe a truck
/ Mystery Part #8
When I saw the first response I thought it was nailed. But wrong size and the drain on your machine is intact so you have to keep looking. Is it bigger or smaller then the one on your air filter canister? Good luck but I think it's a safe assumption it's not from your tractor.
/ Mystery Part #9
Far fetched but could it be a breather for either the front or rear differential?
or again possibly a hydraulic tank breather.
/ Mystery Part #10
/ Mystery Part #11
Looks like a match
/ Mystery Part
Yep, it's definitely a flush drain vacuum breaker. We had an F5 tornado in 2011 pass just north of our property and I am still finding small pieces of debris now and then. Guess this must be some more debris that finally was exposed enough to see. Appreciate the help.
2025 Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
(1) 74"X49" TAILGATE (A64280)
(1) 74"X49"...
Bobcat T590 (A60462)
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-250...
