Mystery Part
/ Mystery Part #1
alexsbuddy
Gold Member
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
Found a small black rubber part, approx. 2" tall by 1.5" wide, on the trail that I drive my tractor on a lot. Figured it might be from my tractor, but darned I can figure it out. Thought I would post some pictures of it and see if anyone knows what it is and where it goes. What do you think it is? 20180401_150633.jpg20180401_150600.jpg20180401_150507.jpg
/ Mystery Part #2
It goes on the air filter canister
/ Mystery Part #3
/ Mystery Part
That was my first thought, but it's the wrong size and mine is intact. I think it must be some type of cap that allows moisture to drain if necessary. It is soft rubber and is flexible.
/ Mystery Part #5
Looks like part for flush meter vacuum breaker :confused: but that's plumbing.
/ Mystery Part #6
Off somebody elses tractor, Maybe a truck
/ Mystery Part #8
When I saw the first response I thought it was nailed. But wrong size and the drain on your machine is intact so you have to keep looking. Is it bigger or smaller then the one on your air filter canister? Good luck but I think it's a safe assumption it's not from your tractor.
/ Mystery Part #9
Far fetched but could it be a breather for either the front or rear differential?
or again possibly a hydraulic tank breather.
/ Mystery Part #10
/ Mystery Part #11
Looks like a match
/ Mystery Part
Yep, it's definitely a flush drain vacuum breaker. We had an F5 tornado in 2011 pass just north of our property and I am still finding small pieces of debris now and then. Guess this must be some more debris that finally was exposed enough to see. Appreciate the help.
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
Caterpillar 914G/IT14G Wheel Loader Parts and Service Manuals (A63117)
Caterpillar...
2024 SCAG SCZ61V Cheetah 60in Zero Turn Mower (A61572)
2024 SCAG SCZ61V...
