Chipper WoodMaxx TM-86H review
/ WoodMaxx TM-86H review #1
spurlocktool
N. California
Kubota BX1500, BX2230
I've left a short report in the "Reviews" section, but thought I would give a more detailed report here. I've owned a BearCat 73554 chipper/shredder for several years and use it to chip orchard prunings and general tree trimmings around the property. I've always wished for a hydraulic feed feature so when I saw the WoodMaxx I read reviews and ordered it up.
I've only used it 4+ hrs. but so far am very impressed with its quality and performance. It is light years ahead of the BearCat in ease of use and safety. The hydraulic feed roller is very aggressive and pulls material in at a controlled rate rather than dangerously jerking it out of your hands as on hand fed models. Y shaped branches feed through fine if flexible but need trimming if large and stiff. I chipped mostly live oak limbs which have very erratic side branching at all angles. The widest spreading 3/4" or larger side branches had to be trimmed but more flexible stuff went right through. Bottom line is feeding is way easier and safer than the BearCat. I would never go back to manual feed.
I was not sure how well my little BX2230 would power it, thinking I would have to reduce the feed speed on larger wood. But surprisingly it barely loads the tractor when running 3" oak or 4" pine through at the highest feed speed.
Another surprise was that the engine just briefly loads when engaging the PTO at idle. With the BearCat I had to bring the idle up a bit, then engage/disengage/engage/disengage/engage to gradually get the chipper flywheel rotating without killing the engine. The Woodmaxx runs smooth with very little vibration and is also quieter than the BearCat.
Here are the problems/quirks that I have found so far:
- As delivered the feed roller would not reverse. This was caused by the safety bar stop bolts not allowing the hydraulic valve to move into the reverse position. Correcting was just a simple adjustment, but I also added flat washers under the nuts to better hold adjustment.
- The threaded shaft between hydraulic valve and safety bar was too long, causing the bar to sit beyond the top of the hopper when in feed position. Side branches would bump the bar into neutral, stopping the feed. So I shortened the shaft so the bar sits below the rim of the hopper as shown below.
- The hopper does not line up exactly with the feed roller housing as shown below. Not a big deal, but I could see branches would sometimes hang up so I used an angle grinder to bevel the ledge.
- Small branches would sometimes catch in the slots at the top corners of the hopper as shown below, stopping the feed. This happened often enough that I welded in 1/2" round rod to close the slots.
- As others have mentioned, the safety bar would sometimes fall into neutral if a large branch started bouncing. So I added a simple rubber bungee to the bar to act as a spring, counteracting the weight of the bar. This seems to have solved the problem, but I may switch to a screen door spring for longevity.
Overall the machine has exceeded my expectations in terms of performance, especially considering the BX2230 is barely above the stated minimum 15 PTO hp. The tractor also handles the 600# weight fine with just the loader on the front to counterbalance. The discharge chute has worked perfectly for everything I've chipped, with no clogging. I find the electronic tach/hr meter really handy to confirm correct PTO speed. Access to the cutter blades is a simple one bolt operation.
I did check the knife-to-bed-knife clearance and found it varies a bit among the four knives, so be sure to choose the closest one if adjusting. I noticed that the bed knife sits in a recess in the bottom of the roller housing, with a gap at its back edge. Small branch stubs seemed to catch on this if they were on the underside of the branch being fed. Not a big deal, but easy feeding is the whole point for me so I might look into adding a thin plate spanning from bed knife to just inside the hopper to make a smooth obstacle free surface.
As others have mentioned the hydraulic valve speed adjustment lever does not have a linear effect. It is numbered 1 to 10, but the feed roller will not begin to turn until around 2-1/2. From 2-1/2 to 3 the speed increases from barely moving to maximum, and stays at max from 3 to 10. So it seems the valve does not match the system flow. This just means that to run at slower than max you need to watch the roller and move the lever in very small increments, maybe 1/2 degree at a time. Once set it seems to stay put fine, plus it has a lock screw if needed.
I found that as expected the slower the feed rate the finer the chips and the fewer longish twigs that came through. So when chipping to make garden mulch I will use a low feed speed, and when just needing to get rid of prunings as fast as possible I'll use the fastest feed.
That's all for now.
-Bill
/ WoodMaxx TM-86H review #2
I agree that it is a great value and I love mine as well. I never had any of the issues you did other than I do occasionally get small branches at the top corner of the hopper catching. I think about fixing it when it happens but it is pretty uncommon so I forget about it. I also have had branches catch the safety bar and stop the feed but again, pretty uncommon so I have not messed with it.
/ WoodMaxx TM-86H review #3
Great write up, spurlocktool - I'm just about to buy one of these TM-86H in green. I went out and just priced the similar competition locally.
They're not really competition as this woodmaxx might be the best value/performance/features for the money by a country mile.
Frontier WC1103 - $4000 new, 2500 used
Woods 1503 and 1504 - $2890, $3390 respectively
Bearcat SC5540 - $2995
However, none of the above (except woodmax) has the size, the flywheel weight nor the hydraulic feed (which is huge). Frankly the Frontier was a joke at the price point.
Also, vSteel, thank you for your post as I was hoping I wouldn't have to deal with the fit and finish problems spurlocktool had. Cheers guys! I'll post a review down the road when I get it!
/ WoodMaxx TM-86H review #4
@spurlocktool and @vsteel
Did you guys opt for the Upgraded PTO shaft? Or did the regular imported shaft work just fine?
Thanks!
/ WoodMaxx TM-86H review #5
Thanks!
I got the American PTO shaft. I figured I would help out our guys and I also use it for my PTO generator so I get double duty out of it.
/ WoodMaxx TM-86H review #6
Would definitely suggest the american PTO. I bought a basic TM-8M? and love the chipper but have not been at all happy with the Chinese PTO shaft and told Woodmaxx. I suggested they not offer the sub standard Chinese shaft. I believe it diminishes an otherwise great unit
/ WoodMaxx TM-86H review #8
/ WoodMaxx TM-86H review #9
Chipper arrived a couple days ago, had to build an adapter to make it fit my quick hitch, I had to do the same for my landscape rake to avoid having to move the top hook up and down. Other than a few bare spots where the paint rubbed through in shipping and a little thumbscrew that was bent over it arrived in fine condition. Jim said he would send a new thumbscrew and some touch up paint my way so it will all be good soon, they have very good Customer Service. The setup and checkout instructions were straightforward and easy to follow, as others mentioned the most painful part was trickling 5 gallons of oil into the small fill port. Got it filled and the air purged in time to chip a few branches before dark and it lived up to it's reputation, my initial impression is that it is a very impressive machine. The hydraulic feed is what tipped me over to spend the cash on the Woodmaxx vs a much cheaper self feeding unit. Both for the safety aspects as well as regulating feed speed to avoid bogging down and plugging it up as I only have 18.5 PTO hp. I am looking forward to many hours of reducing brush and limbs to usable chips for my Wife's garden as well as 'paving' tractor trails in the woods with chips to avoid mucking them up.
/ WoodMaxx TM-86H review #10
What was wrong with your Chinese PTO shaft?
Was wondering the same - I have the Chinese one on our chipper (running around 50hp) and have not noticed any issues or problems at all.
/ WoodMaxx TM-86H review #11
I purchased the TM-86H last fall for use with my Kubota BX-2200. After setting it up and filling the hydraulic tank with oil the hydraulic feed did not work. I got to this point just before bad weather arrived and after spending the better part of a day without getting the feed rollers going I had to switch over to snow blowing. Now I really need to use it to deal with a lot of spring storm damage. Does anyone have a recommended procedure to diagnose the hydraulic problem? I have not been able to get technical support from WoodMaxx.
/ WoodMaxx TM-86H review #12
Did you check the lines to make sure they are tight and not leaking? When you turn your PTO on is the pump spinning? Loose belt perhaps? What else can you tell us?
I only called Woodmaxx once (called the # on the website) and they put me in touch with someone soon as they answered. May want to call them?
/ WoodMaxx TM-86H review #13
Also purge the system to get air out ?
/ WoodMaxx TM-86H review #14
Thanks much for the replies. I will recheck after remounting the unit this week (we are expecting snow again tomorrow). I made a mistake in purchasing this unit too close to end of season. Delivery was longer than promised and did not anticipate needing quick hitch to mount. Result was a furious attempt to set up and operate hours before coming snow storm. As far as I could tell all mechanical couplings (belt, shaft, push bar, hydraulic switch) were OK. Unit was up to speed for >10 minutes. I'm not sure how to purge the system as it is a short closed circuit with reservoir below and I believe no bleeder valve. My next step was going to be to break the line and inject some oil in hopes of getting it to improve pump seal and resultant pickup vacuum. Instructions seem to expect unit to self purge. I will contact factory during next run but so far they (he) has been no help.
/ WoodMaxx TM-86H review #15
BTW. When I purchased the TM-86H I was planning to direct connect to my BX 2200. That turned out to be impossible (as well as unwise) because even if the Chinese shaft were to be cut to fit, the chipper could not be leveled to the ground after attachment. Fortunately I decided not to cut the shaft until I received a quick hitch because the hitch required the shaft to be longer and allowed proper leveling on the ground during operation. After working with the quick hitch I realized how unwise it would have been not to get it. Anyone with a subcompact tractor who is considering this chipper should carefully investigate this issue. The bottom line for me was that a BX 2200 requires a quick hitch to properly deploy a TM-86H
/ WoodMaxx TM-86H review #16
That's very disappointing...I was of the impression that their service was very good
/ WoodMaxx TM-86H review #18
I'm going to follow this pretty closely...I was considering buying a Woodmaxx chipper this year. But if their support isn't so good, maybe I'll reconsider...
/ WoodMaxx TM-86H review #19
I am surprised by the negative comment about customer service from Woodmaxx. I have contacted them three times over the last four years and have had nothing but stellar advice, answers, and instruction. I have been most pleased with my WM-8H. I run it with the standard import drive shaft and have no complaints about any of it.
/ WoodMaxx TM-86H review #20
Couple things to add, I have a machine from a different manufacturer but IMO they are all near identical clones of one another. The things I would check would be fluid level, leaks, linkage adjustment, along with making sure the belts are turning the pump.
Do you have an upper and lower infeed motor/roller? Are both upper and lower feed wheels/rollers stopping or just one?
These are pretty straight forward machines and are (or should be) tested from the factory. I know mine had fluid in the lines so I know it was tested. I’m betting it’s something simple that is causing your issue. Best of luck, keep us posted with what you find. Rye.
