Rounded off drain plug
/ Rounded off drain plug #21
If the drain plug has a sealing washer between the plug and the place where it threads in , it will have a straight thread not a tapered thread like plumbing fitting so be very careful with what you put back because if you now damage the threads with the wrong plug thread you are in a really big mess.
Often the straight threaded plugs, especially likely if your Ford has any British connection, will be using a Whitworth thread. It will appear very similar to an American fine thread on a bolt but the American National Fine thread has a 60 degree pitch where as the Whitworth thread pitch is 55 degrees.
The NF bolt will appear to be correct at the start of you screwing it in, but the more you screw it in, the bigger the conflict between the 55 degree threads and the 60 degree threads and the hole will be seriously stripped.
This link will direct you to a description of the many threads around and will contain more than you will want to know.; I send you to it because it will help you understand what you replace the plug with is critical.
https://www.teesing.com/files/en/brochures/Type-of-thread.pdf
If you invest some $ in having an experienced mechanic or machinist remove the old plug, now you know you have the correct thread characteristics. A new head can be welded on the old base portion of the plug and re used.
Tractor salvage yards are another possible source for your plug.
Don't turn a small job into a much bigger one requiring helicoils or inserts.
Dave M7040
/ Rounded off drain plug #22
Have you tried BEATING a socket on it?? The extra pounding might help break it loose..??
/ Rounded off drain plug #23
Assuming it is an early 4 cylinder all American made Ford 960, these did use some square head tapered pipe plugs in the housings. Hard to believe it's gotten so tight, but who knows what a previous owner/operator may have done or installed, possibly improperly.
/ Rounded off drain plug #24
No go with a pipe wrench, simply can't get a good grip on it.
Is the pipe wrench too big?
[video]https://www.google.ca/search?q=pipe+wrench+use&client=safari&hl=en-ca&prmd=ivsn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiGjKnex5baAhUBUa0KHVOeA5IQ_AUIESgB&biw=1024&bih=728#imgrc=DCz-mKrBy5SS4M:[/video]
/ Rounded off drain plug #25
These plugs are the square head NPT. More than likely the square head doesn't just have rounded corners, but its now a rounded tapered cone so any wrench or socket pulls away/off the head as you apply force. I'd try to grind or cut some new flat sides, or a slot like mentioned above. Otherwise a large nut tack welded to it would be my choice.
/ Rounded off drain plug #26
So once you get his plug out I would not replace it with a similar plug. You can get brass pipe plugs with a six sided bolt head which is what I would use. You aren't as likely to be tempted to use a vice grip or a crescent wrench since a proper sized socket will now work.
/ Rounded off drain plug #27
I don't know, since the old one lasted 60 years I might stick with steel. ;)
I'm going to talk to a small welding/repair shop down the road about removing that plug. Any attempts I make simply end up stripping it bit by bit more. There's a bar that runs underneath the tractor side to side connecting to the FEL mounting and it sits directly underneath that plug with about 1½" of space between it and the plug head.
/ Rounded off drain plug #29
Good luck, That might be the best way let us know how you make out:)
/ Rounded off drain plug #30
I'm going to talk to a small welding/repair shop down the road about removing that plug. Any attempts I make simply end up stripping it bit by bit more. There's a bar that runs underneath the tractor side to side connecting to the FEL mounting and it sits directly underneath that plug with about 1ス" of space between it and the plug head.
What ever you do don't try the bolt extractor I showed above. That will likely remove it, but then you wouldn't be able to pay the shop so that they can use their bolt extractor kit. :confused2:
/ Rounded off drain plug #31
or, again, use the correct tool to remove the bolt........
Bingo. Quit being lazy and use the right size 6 point socket and it wouldn’t be a problem. Since that’s not much use for the problem I find a pipe wrench is the best for sure jobs.
/ Rounded off drain plug #32
He stated above there is only 1.5 inches between the plug head and part of the loader mounting frame..................
/ Rounded off drain plug #33
Looking at the tool above, if he can get it on the bolt he can use a wrench to turn it from the side.
/ Rounded off drain plug #34
I have a similar set and the middle ones are just under 1.5 inches and the bigger ones are just over. I have found you sometimes need to pound them on to work the best. If you use one that is too big it may continue to strip, been there done that. If there is room it may work, not saying it won't . The ones in my set that could possibly work would very tight squeeze if they fit at all and then no room to pound it on.
/ Rounded off drain plug #35
I think it has been established this was a square head plug. 6 point socket wouldn't work very well.
Yes, square head.
Here's the current state of the plug. That bar should be removable, bolt on each end. The loader mounts to the frame on the front under the engine and to axle on the rear, just a support bar I suppose. Johnkn, I've tried those extractors as well, although the one I tried was the one that fit in it's current state. Once I remove the bar I'll look into using the next size down, 1/2". Bolt head would normally be 9/16"
/ Rounded off drain plug #37
I still don't see why a small pipe wrench with a pipe slipped over the handle as an extension won't back that plug off. It's most likely a right handed thread, may be mis-threaded in and a replacement may be difficult to install. But I wouldn't screw around with so many options. Put a Stilson type self tightening wrench on the head and yank it off. If it breaks off, drill it out and put a left handed extractor on the job.
/ Rounded off drain plug #38
I always use a 6 point socket when turning a drain plug, better safe than sorry. I sometimes have the local jiffy lube type place do my oil if I’m am very busy. Once they rounded off the plug on my F250 and mostly stripped the threads which I found on the next oil change that I did. I took the car to the oil change place with the plug in hand and showed it to them. They gave me a new plug and a coupon for a free oil change.
Stated earlier, I can't get a pipe wrench to grip and stay. Tight spot makes it harder to tighten up the wrench, combined with the metal that's been bunched around, and I, personally, can't get it to work for me.
/ Rounded off drain plug #40
Once those plugs get to that point, they are a bear to get out. The easiest way I've found is to find a nut that will just slip over the square plug. Then weld the snot out of it. Then you can use the proper wrench to get it back out.
You can get a a set of 8 point impact sockets from harbor freight pretty reasonably that are designed for the square plugs.
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
Gravity Flow Wagon (A64127)
Gravity Flow Wagon...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2011 New Holland HT154 Rake (A63688)
2011 New Holland...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
