So what would you have done different with your new shop?
   / So what would you have done different with your new shop? #11
I wish I would have used plywood on the interior instead of drywall. The drywall is getting damaged from no heat and moisture. Plus with plywood you can hang things anywhere.
   / So what would you have done different with your new shop? #12
I was going to add; finish the interior wall/ceiling to the extent you plan to PRIOR to moving in all your chit! :thumbsup:
I now have 16' ceilings & walls that need to be finished, the foam is in the walls but now "closing" the interior wall's & ceiling is much easier than dealing with all of my crap that now is in the way. :mad:
Another good one. I will have to empty my shop to put in my mezzanine storage. We are blessed with 4 or 5 months free of precipitation so I can just stack the crap outside while I do the build and probably bring in a lift to insulate the ceiling first.
   / So what would you have done different with your new shop? #13
Great idea there - even OSB would work and might be a tad less expensive?
   / So what would you have done different with your new shop? #14
OSB on the walls, metal on the ceiling. I actually have T-11 as a wainscot and then 8 feet OSB to ceiling. Looks better than all OSB. What I wish I had done differently is surface mount all the electrical in conduit rather than run through the walls and above the ceiling. Would make insulation and wall/ceiling finish easier and allow easy mods later if necessary.
   / So what would you have done different with your new shop? #15
Good point on the electrical. It would also make it easier to add to it later if you wanted.
   / So what would you have done different with your new shop? #16
A bit off posting (my apologies for that) When you say "foam" did you have it sprayed or are you talking about ridged sheets? Closed-cell-Foaming is one thing I have considered for retro-insulating my ceiling and I'd be interested in other's experience.
   / So what would you have done different with your new shop? #17
Vapor barrier and foam under the floor is cheap.
Bigger amperage and more slots for breakers than you think you need.
Insulate walls and ceiling before you fill up the shop.
Plumbing you might want someday.
Frame up for windows or doors of any kind you might want later. Cover with tin for now.
Rebar in the floor is good.
   / So what would you have done different with your new shop? #18
- PEX in the floor and heat it with a water heater.
- Any thoughts to storage above the ceiling, like attic or 2nd floor?
- Air lines all the way around, and down the center of the ceiling for retractable hose reels.
- Small, quiet room for the air compressor to live in.
- If you ever do mitre saw work, its nice to have a long wall with a table the full length of the shop AND be able to run any long stock out the door on support stands. For example, my garage is only 20' deep. I have a miter saw on the wall in the middle of the wall. I can cut 12' lengths to the left, but infinite to the right, as the overhead door opens to my right. I should have put the miter saw table closer to the door for longer thenghts to the left. Don't need it often, but when I do, I do. For some stock, it's just a matter of reversing the angle and turning the workpiece around, but sometime that's not possible. Anyhow, something to think about.
   / So what would you have done different with your new shop? #19
Skylights in the wall that the sun is shining on in the picture and a wider shed.
   / So what would you have done different with your new shop? #20
What I did right and will do again.
Concrete floors
OSB on the walls
Outlets every four feet
Two work benches at the same height with a chop saw bench in between them
Lots of overhead lighting
Tons of open shelves without doors so I can see what's there
Hand tools hanging on the wall so I can see all of them and know if any are missing
Sink with hot and cold water
12 foot tall walls
What I did wrong
No ceiling with insulation. It's just a metal roof and the heat can get crazy bad in summer, freezing cold in winter and impossible to warm up
Ten foot wide roll up door should be 12 foot wide or wider.
Allowed my wife to store stuff in there!!!! Get a lock on it and never give your wife the key!!!!!
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
54in Loader Fork Attachment (A59228)
54in Loader Fork...
Quick Attach Hyd. Compact Roller (A59814)
Quick Attach Hyd...
Brent 420 Grain Cart (A56438)
Brent 420 Grain...
