LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,725
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I appreciate the feedback. Went out again today and eyeballed the area. I have two areas, one five rows wide with ten feet center pathway, then another five rows wide, then another ten feet to the next rental area, which is a single 8 row wide field.
So a five, a five and an eight.
Thinking of putting the SilverQueen and Peaches 'n Cream in one field, the 8 row one. Then in the field with two five row sections, keeping the yellow corn on one side of that middle pathway, and the white corn on the other.
5 rows of each variety, separated by a space between varieties.
Yes to irrigation; just ran a one inch pipe from house over to garden, backed up by 1.5hp sprinkler pump.
Have elevated sprinklers, figured I'd set them up in the middle pathway between the corn and water that way.
I realize that some of my corn may come out as mutts, but as long as it's good eating mutts...
I have a ton of drip hose but using that elsewhere. If we get a drought, one way or the other this will get watered.
Any separation will help with the cross pollination also the Silver Queen and Peaches and Cream have a 10-12 day maturity difference which will also give them different pollination dates, you can assist the pollination in small fields by gently shaking the stalk when the tassels are heavy with pollen. When the research farms are working on new varieties they will place bags over the tassels and silks and even detassel some plants, when seed corn is grown quite often they used to plant 4 rows of one variety then two rows of another, as the corn in the four row section was growing they would go in with a mower and remove the tassels just leaving the two bull rows to pollinate.
As far as sprouting corn seedlings you should get some nice early corn. Up here some of the commercial growers will lay black plastic down to draw the suns heat into the ground, then plant thru the plastic and lay a clear plastic on top to try and get the "first" locally grown corn.
So enjoy your gardening and corn growing.
