Front end loader hydralics slow after hose replacement
   / Front end loader hydralics slow after hose replacement #1
JungleJim03
DICKINSON
New Holland 2002 TC30
Lots of abuse here on my part, lets get that out of the way.
2002 new holland tc30 with 7308 quick disconnect drive away front end loader.
this is a 15+ year old machine, 1080 hours and I waited til hoses blew to replace.
Was experiencing some bleed off on loader... assume bypass in valve is bad.
blew a couple hoses, decided I would address valve... and hoses
Walked out of loader.. and removed control valve... new one is on its way.
Gonna be a minute... so I reattached all lines hose etc.
Drained case, put in new filter, new fluid, walked back under loader....
I have traced all hoses from connects to cylinders... 99% sure all are in correct position
Hydraulics are extremely slow to the point of not functioning....
Looking at "purging"... seem to hear pump "whining".... ALL four pairs of cylinders have same issue.
As I cycle through system... lift will be slow on raise... then after extension... quick... then slow again.
Did the valve just "fry" during this process? or is there a bleeding procedure.
One more FUN note... did not realize that Hurricane Harvey had gotten water in system...
Fluid was terrible...
Planning on new filter and new fluid AGAIN with new valve install.
   / Front end loader hydralics slow after hose replacement #2
If everything Is hooked up right and the hyd oil is full then cycling the loader will bleed the air out Make sure the couplers are on correct
Can this take a considerable amount of cycles of controls?
   / Front end loader hydralics slow after hose replacement #4
More than 3 or 4 times but not 50 . Do one first open and close the bucket till its ok then raise and lower the loader
   / Front end loader hydralics slow after hose replacement #5
Try resetting all the QD's...if you have not done so already...
   / Front end loader hydralics slow after hose replacement #6
Air in the FEL lines should not make the system not move. Move erratic yes but no movement no. Air should just make the system spongy but still raise at close to normal speed.
Since not how this FEL connects how many hoses do you have to remove? 4 or more?
no.... this is persistent... thats why i came to the experts...
want to check connects.... hoses come in two bundles... one from arm... one from bucket.
top connects
bottom connects
   / Front end loader hydralics slow after hose replacement #8
Did you try to disconnect and reconnect the hoses ?
haven't done all four
I was told this valve recircs.... should I run tractor a bit without connects?
   / Front end loader hydralics slow after hose replacement #10
NO leave the hoses on
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
VOLVO EC240CL LONG REACH EXCAVATOR (A52705)
VOLVO EC240CL LONG...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
