   / Share Pics of People Hauling or Towing Something Wrong #7,301
That is when you inform them that you have a tractor with a backhoe and you can make the problem "go away"
David
I certainly would have leaned more that direction if he wasn't a local cop. Serious POS.
   / Share Pics of People Hauling or Towing Something Wrong #7,302
Looks like truck has front end damage and struck other vehicle quite hard. Probably broke whatever tie downs were being used.
Ya.. You can see a snapped green strap on the trailer so he had it tied down, just not good enough.
   / Share Pics of People Hauling or Towing Something Wrong #7,304
Seeing the trackhoe hitting the bridge brought back memories for me. When I was 16 I would drive truck during the summers hauling some good size loads around Utah, Colorado and Wyoming. One time I hauled a loader/backhoe from southern Utah to Salt Lake City. The backhoe didn't run so I had to nose the trailer down in front of the backhoe and drag it up onto the trailer with the trucks winch. The truck and trailer were setup for oil field work and I was well versed in using them so it wasn't a big deal.
The trailer wasn't a long trailer, only about 30' to 35' long so with the edge of the front bucket hanging over the back of the trailer about a foot and the backhoe bucket right at the front of the trailer it put the backhoe boom just over 13' high which was plenty legal.
The trip went well until I got into SLC. I'm running along in the outside lane of the freeway, bumper to bumper traffic in all lanes but moving along at a good clip. Then I see a sign, low clearance ahead, 13 feet. About a half second of running the math told me things were not gonna fit so I carefully start shutting down the truck but if I stop too fast cars are going to run into the back of me. If I don't shut down fast enough the results should be obvious. Now another problem crops up, a highway patrol car is parked on the shoulder so I can't get over, I have to stay in lane.
Long story short, I got stopped with the backhoe boom about 10' from hitting the bridge. No cars ran into me so life was good. But then the passenger door is jerked open and the highway patrolman starts screaming at me to get the #$%&* truck moving. I didn't say a word, just pointed up. He looked at the bridge and the boom, said some things that would make a sailor blush. I mentioned that if he wanted to move his car and direct traffic I would try to get into the bar ditch so I could get under the bridge. In a very unkind and direct way he let me know what I could do with the truck, backhoe and bridge. He then slammed the door, ran to his car and left.
It was an interesting few moments.
   / Share Pics of People Hauling or Towing Something Wrong #7,305
Quick thinking on your part. :thumbsup: Not so much for the patrolman
   / Share Pics of People Hauling or Towing Something Wrong #7,306
Back in 1987 the local US Forest Service engineering group had a Case 580 cab backhoe on their tandem axle deck over but it was loaded backwards this time without lowering the boom to the deck like normal and hit the 14ft railroad bridge and pushed the boom and dipper half way through the cab, should of seen the pivot and boom on the hoe it was mangled bad.
David
   / Share Pics of People Hauling or Towing Something Wrong #7,307
I think the ex wouldn’t have left that lowboy if it was just sitting on it unchained. It drove the machine down so hard it mashed the trailer. Hope that wasn’t an important bridge. Tough repair.
   / Share Pics of People Hauling or Towing Something Wrong #7,309
dont understand why some of lowboy drivers load excavators with the boom to the front of the trailer. if you load them boom to the rear, even if it does hit a bridge, it will smash the boom down into the trailer, instead of levering it up into the bridge. i always load them boom to the rear. that also looks to be a long reach boom on that particular one, so if loaded the other way, the extra legth of the boom could just hang off the back of the trailer
   / Share Pics of People Hauling or Towing Something Wrong #7,310
Most lowbeds have a well between the rear frame rails for the boom to sit in making it lower
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2012 NORAM POWER...
Enmark Z Spray (A53316)
Enmark Z Spray...
Man Cave Metal Sign (A57454)
Man Cave Metal...
