How to store your snowblower ....
/ How to store your snowblower .... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Here is how I store my blower for the summer [ I have a backup tractor with a 6' blade, so don't have a cow ]. Once you drop it flat onto the ground and get it all unhooked, back the tractor away, etc... I lift it off the floor using two floor jacks, you can do it with one, but it is easier and faster with two. The lift points I use on mine is almost a perfect balance point, so you might have to use others on a smaller blower. I lift it up high enough to put the center cart underneath. This also is high enough that I can put the two under the front part of the blower itself. Then lift the rear by hand [ just about weightless at this point ] and put the last cart under the rear. Then lower it to the ground. You can move it fairly easy, but I usually use a wheelbarrow handle to persuade it which direction I want it to go. Put the chipper on [ it has it's own roll around cart ], and my tractor is ready for knocking some trees down IF THE SNOW EVER LEAVES...... :)
[ pictures are arse backwards for some reason... ???? ]
/ How to store your snowblower .... #2
That’s one to ensure we will have 6 more weeks of heavy snow! The jinx is on!!
Setup looks good!
/ How to store your snowblower .... #3
When I had the Gravely, both the snow blower and plow could be stored in a very small space.
Ralph
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
Willmar 4550 Wrangler Articulating Loader (A63118)
Willmar 4550...
2012 John Deere 6170R (A57148)
2012 John Deere...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
New/Unused AGT SDA-140W Wheel Loader (A61166)
New/Unused AGT...
