Black Diamond log splitter (3pt)
/ Black Diamond log splitter (3pt) #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Anyone have or use one? Thinking of getting one and the price seems decent (and in stock at our local store) and was wondering what you all thought.
Black Diamond 3 Point Mount Log Splitter YTL-14-25 : Rural King
I don't split a lot of wood, say ス a cord a year currently, maybe 1 cord. We may get an out side wood burner down the road so I am sure I will split some wood for that but a lot will go in whole.
I don't need blazing speed so I was thinking this would work well.
I am going to run it on a MX5100 - 9.5 GPM (not counting steering)
I have two rear remotes that auto center - can I hook to one of them and just hook it so it stays open?
THANKS
/ Black Diamond log splitter (3pt) #2
The top section is identical to the one I bought at tractor supply, the base is different, the only thing I noticed is it is long 83” you have to be careful not to hit anything when turning, as far as the splitter goes it works great.
/ Black Diamond log splitter (3pt) #3
In that same price range you might compare to the Power Horse 3 pt splitter by Northern Tool.
THANKS all! I will also check out the Power horse. Figure I will use it two times a year to split up a tree or two so no need to invest a ton on a splitter.
/ Black Diamond log splitter (3pt) #5
I too am looking at log splitters. I find absolutely amazing how the descriptions in the ad don;t match the product. For example, the link above is for 3pt yet the description on the site talks about filters, 14 gpm 2 stage pump, etc. i see it time and again in TSC as well as others.
I noticed that also. LOL Seems they use the same description for the 3pt and the stand alone. Doubt the marketing/computer people have a clue what they describing or posting ads about.
/ Black Diamond log splitter (3pt) #7
E-commerce sites like that are often done by cheap contract Indian coding houses. Nothing against Indian engineers as I've worked with some brilliant ones but they're not the guys doing e-commerce sites as cheaply as possible. Between bad code and bad data in the databases there's going to be a lot of errors.
But hey, it's cheap!
/ Black Diamond log splitter (3pt) #8
I haven't done any research, but maybe they're running a pump off the pto vs a power beyond scv.
Two different types but still 3pt.
The black max runs straight to the tractors hydro (Got too see one in person at the local store) - looks pretty decent for the money.
/ Black Diamond log splitter (3pt) #10
It would be great if black diamond had a video of it in use splitting wood and tell us what gpm it was hooked into. i wonder if it is open center valving. the one video on you tube by North40 shows it in use splitting one log but you will see they have it piped to a stationary pump not to a tractor.
/ Black Diamond log splitter (3pt) #11
It would add a lot of money to the price of the woodsplitter. It would require a $500 pto pump, then a hydraulic reservoir, filtration, extra hoses etc. I ended up doing this for a homemade woodsplitter I made, and it works better then plug-in connections, but more expensive too.
/ Black Diamond log splitter (3pt) #12
I had one of these and it was pretty good for what it was. I was just splitting for recreational fires and fireplace for holidays. I installed an outdoor wood boiler and it wasn't the best for that. Kinda slow and the wood was always all over the ground. I went right to having to split 10-12 cord or more per year and other than a skid steer with an upside down splitter, The best thing I ended up with was a stand alone regular splitter. I added another valve and built a lift that made life wonderful. It would lift 30" rounds up onto the splitter and the pieces split out onto a modified table so I didn't have to pick them up off the ground. It's fast, powerful and on wheels. Plus I didn't have to smell my tractor diesel or have it running for hours at a time. All of this stuff is out there used too and it pretty much lasts for ever or is easy to replace components. Good Luck..
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2022 EZ-GO ELITE...
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
