MPower 85 Hydraulics
/ MPower 85 Hydraulics #1
Yoteroller
Mountain Home, Idaho
Mahindra mPower 85
Looking to understand the whole hydraulics flow and flow availability for implements with the M85. Specs show open center and 17 gpm flow and then lists the power steering as 5.something for the steering. So what I think this means is 11.whatever GPM is available for implement use. Is that right? Thanks in advance for any help...
/ MPower 85 Hydraulics #2
Did you upgrade from the 7060? I believe that the 7060 only has an 11 GPM implement pump.
The MPower 85 should have 17GPM for implements, just as it lists out.
You will find that typically when there is a single listing, then those 2 are combined. But with separate listings, then that is what each function has.
Super and thanks for the reply. I did upgrade! I teter tottered 1 too many times picking loaded bean boxes off my flatbed. I was concerned that going from the 7060 to the M85 wouldn't be that much of a difference and there I'd be - able to pick a few more pounds but still be on the edge. The dealer brought out a cab version to try it out real world and it did everything I need and more. I was really surprised how much "more" tractor the M85 is over the 7060. Don't get me wrong the 7060 was great just a little undersized for my needs. Too bad I couldn't afford both!
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2013 John Deere 210G Excavator (A60352)
2013 John Deere...
832619 (A61166)
832619 (A61166)
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
