Front End Loader for Chinese Tractor
/ Front End Loader for Chinese Tractor #1
Lodi
Member
walworth WI.
Lu Zhong
Hello and good day
I have a Luzhong 254.
Was wondering if possible to purchase a new front end loader
that would fit this little tractor.
The old one is just too difficult to find parts that fit. (mainly hydraulic hoses)
Thanks
/ Front End Loader for Chinese Tractor #2
I've got a ts354. It's got a koyker loader on it.
/ Front End Loader for Chinese Tractor #3
Looks very similar to my kama. Circle G @615 315-5686
He could probably tell you what loader bracket would fit. The jinma and foton Tractors are are very similar.
Thanks Mr. B
Will try
/ Front End Loader for Chinese Tractor #5
Before I dropped $3-$4000 on a new loader, I would REALLY TRY HARD to find the correct hose ( or I suspect correct hydraulic fitting being the main issue). Is the issue with fittings? Check with someone like British (BSP) and Metric Fittings first. Pins, valves , hydraulic seals and hard lines should be able to be easily sourced and even complete cylinder replacement would be MUCH cheaper that a new FEL.
Yes you are probably right.
The banjo type hose fittings are okay, but can't find here. Nor the seals that go with them.
Maybe I just need a new controller with common threads.
Then I could just buy pre-made hoses at the local parts shop.
/ Front End Loader for Chinese Tractor #7
If your valve is the problem you can find a joystick valve to replace it at surplus center for about 250. The cylinders can have another fitting welded on. Much cheaper than a new loader.
/ Front End Loader for Chinese Tractor #8
I have a shop near me that makes hoses on the spot. Bring in your old one and walk out with a new one. Try going to the town highway department and ask where they get their hoses replaced.
/ Front End Loader for Chinese Tractor #9
Farm Boys carries some of the banjo style hoses.
It may also be possible to carefully cut the banjo fitting itself off and have a local hydraulics shop add it to a new hose.
Just make sure and bring the old (bad ) hose to the shop with you.
/ Front End Loader for Chinese Tractor #10
/ Front End Loader for Chinese Tractor #12
Try Affordable Tractor in Texas. They are the go to for parts and advice.
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Vandale Feed Wagon (A65640)
Vandale Feed Wagon...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
(6) 250 Gal Chemical Totes (A64127)
(6) 250 Gal...
CASE 105C (A62177)
CASE 105C (A62177)
