Comparison Husqvarna GT48DXLS Compared to John Deere
/ Husqvarna GT48DXLS Compared to John Deere #161
I wouldn't get hung up on fabricated versus stamped decks as the only factor for the deck. Also consider gauge of the material, quality of the brackets and wheels, and flow/performance. Manufacturing advances make it possible to build a heavier stamped deck nowadays, whereas in the past it had to be fabricated. Stamped tends to have better airflow and less clogging/buildup issues because they can build it with smoother shapes. Many of the high-end professional zero-turn mowers (of multiple brands) come with a stamped deck nowadays, and same goes for some of the mid-mount-mowers on compact tractors. Really comes down to what they can manufacture based on the various requirements and specs. If they can do it with a stamping, that's the best of both worlds.
Certainly won't argue with you on that. We have come a LONG ways in stamping/casting tech.
The fabbed shroud on the Husq is a very strong unit and I really need that on my place due to the number of tree stumps, mostly those little saplings that around about 1-2 in in diameter and stick up to catch things. Hitting and bending the front of the shroud can be a catastrophic mess when the blade hit the bent metal and that is what I want to avoid on my place...
/ Husqvarna GT48DXLS Compared to John Deere #162
If you have a way to knock down those stumps before you get a new mower, do it -- I'd be afraid of causing serious damage to any mower. If not the deck, then to the spindles. Years ago I hit a small 2" stump and it and bent one of the spindle shafts. That was a direct blade-on-stump hit. My fault as I was reversing at the time and not paying attention, but I think the real problem was that I should have got rid of the stump before getting in that area with a mower. It had been a small cypress tree that died and I had cut it off low, but not low enough.
The mower deck on my Deere will disengage the electric PTO if there is any sort of impact, but I don't know if it would prevent damage when hitting a stump and I'm not about to test it!
/ Husqvarna GT48DXLS Compared to John Deere #163
100% right and have been working on that for years, tween those and the ROCKS its a minefield...
/ Husqvarna GT48DXLS Compared to John Deere #164
The reason I wanted the fabricated deck vs stamped is that in 10 or 20 years things will rust. I can repair a fabricated deck much easier than a stamped one.
/ Husqvarna GT48DXLS Compared to John Deere #165
For those of you wondering what happened to the GT48DXLS, it was a limited spring release only for 2017. There are a few new ones here and there but they are still priced at $2999. At the end of last season one could be had for $2650. The D designation in the model specifies "dealer only" as it you will not find it in a box store. Lastly, the GT48DXLS was replaced by the TS 348D this year. It carries the same transaxle but with a Kohler engine. They upgraded the seat and removed the analog gauges above the steering wheel in favor of an hour meter with service-minder. The price for this model is still $2999. There is also a TS 348XD which gives you the Kawasaki FR730V as well as LED headlights, Bluetooth connectivity and possibly a dash mounted fuel gauge. All of this will set you back $3399. I have seen the TS 348D in person and it is a nice improvement over the GT48DXLS with the exception of the Kohler. The seat alone is worth the upgrade in my opinion. The TS 348XD will have to be ordered from a dealer with units possibly showing up on floors in the coming months.
/ Husqvarna GT48DXLS Compared to John Deere #166
What would the Bluetooth be used for?
/ Husqvarna GT48DXLS Compared to John Deere #167
I was really dreaming of them coming out with a 54" deck, Kawasaki engine, with a heavy duty fast cut hydrostatic transmission. I have an aging 54" deck, Courage with the Hydro-Great 730... I'd like to replace it with one that has a better engine and transmission but would never want a smaller deck. If anything, go to a 60" deck!
/ Husqvarna GT48DXLS Compared to John Deere #168
The Bluetooth is for their app which stores mower related data like hours of use and service reminders. The display on the mower has LED indicators for equipment status such as PTO engagement, oil pressure and so on. The unit also emits an audible alert for various issues the mower may have. A search for the TS 348XD manual will show you these features in red text. There is a new model with a 54" deck the TS 354D which has the 54" clear-cut deck, Kawasaki engine, K66 locker and the upgraded seat. It does not appear to have to LED headlights or the new connected feature. Price is $3499 for that model.
Husqvarna Riding Lawn Mowers TS 354D
/ Husqvarna GT48DXLS Compared to John Deere #169
The TS354D is a 54" cut.
/ Husqvarna GT48DXLS Compared to John Deere #170
But it is not the "Fast Cut" and it has a junk Briggs engine. Take that deck/frame and give me a Kawasaki or even a Kohler 7000 series engine, and give me a 8-8.5 MPH cut speed and I would be in. My current unit is an older 7.5 MPH fast cut, Kohler Courage (Junk, but still running at 580 hours), and 54" deck. I do not want smaller cut path, I do not want slower cut speeds, and I do not another bottom end engine. I want the upgraded version (the unicorn version?) of my old gem. If Husqvarna made a Kawasaki powered, HD (K66 or better) hydro diff-lock fast cut (8 or 8.5 MPH) with a 60" deck and sell at around $4000-$4300.... they couldn't make them fast enough to keep up with demand.
/ Husqvarna GT48DXLS Compared to John Deere #171
Their website has inconsistencies, however it says it has a Kawasaki engine. It also says it has a fast hydrostatic transmission, and in one areas it says it does not have a locking differential, and in another area it says it does - so who knows?
Compare
/ Husqvarna GT48DXLS Compared to John Deere #172
You do know that these companies are I'm business to make money right? What you described is a $9000 John Deere; And you want Husqvarna to sell it for $4300? There is a reason why so many manufacturers and so many mowers exist; so that they can compete on every level of features, costs and customers either willing or not willing to pay extra for these things. I am not trying to knock you but Husqvarna in some cases is already ahead of MTD and John Deere in regards to value, but even these manufacturers have to be cared of creating a product that is undervalued in such a market. I think there is something to be desired in each of their products, such as Deere's signature series engine, Cub Cadet's steering, Husqvarna's choice of transmissions with ELD and a reasonable price to go with all that. But, at the end of the day we all find ourselves sacrificing at least one thing that we want in our equipment because not one manufacturers makes a "perfect" tool for everyone and there is always something better out there.
/ Husqvarna GT48DXLS Compared to John Deere #173
But Husqvarna has the Kawasaki engine in the line up, they have a 54" deck on the shelf, they the fast cut transmission... They just haven't put it all together.
/ Husqvarna GT48DXLS Compared to John Deere #174
Not sure you can trust their web site, but ...
HUSQVARNA TS 354X
Be the first to write a review
Heavy duty garden tractor with unbeaten capabilities in its class. Versatile ClearCut™ cutting deck and powerful, reliable engine mean fast mowing anytime, anywhere – with a perfect result every time. Commercial grade, extra fast ground-engaging transmission works with large, wide rear tyres to enable tough usage without overheating, plus great traction and less damage to the lawn. Improved quality, comfort and ergonomics join smart connectivity for an optimal driving and ownership experience, including service and failure alerts and tilt warning, reducing maintenance and increasing productivity.
Motor/engine manufacturer
Kawasaki
Transmission type
Commercial Grade Hydrostat, Electric Locking Differential
Cutting width 54 in
Select product variant
$3,399.95
MSRP
/ Husqvarna GT48DXLS Compared to John Deere #175
HUSQVARNA TS 354X
Heavy duty garden tractor with unbeaten capabilities in its class. Versatile ClearCut cutting deck and powerful, reliable engine mean fast mowing anytime, anywhere with a perfect result every time. Commercial grade, extra fast ground-engaging transmission works with large, wide rear tyres to enable tough usage without overheating, plus great traction and less damage to the lawn. Improved quality, comfort and ergonomics join smart connectivity for an optimal driving and ownership experience, including service and failure alerts and tilt warning, reducing maintenance and increasing productivity.
Kawasaki
Transmission type
Cutting width 54 in
$3,399.95
MSRP
Their website is confusing. At the bottom of the page where it lists the specs it shows tuff-torq for the transmission, but the illustrated parts list shows a hydro gear g730. This in fact may be your perfect tractor minus the 60" deck. How fast does this trans allow a mower like this to travel when a K66 will do about 5.2-5.5mph? A look at the operators manual shows that the TS 354X does not have a differential lock. The TS 354XD for $3499 has the differential lock but again it is a K66ELD.
/ Husqvarna GT48DXLS Compared to John Deere #176
The G730 Hydro Gear is the 7.5 mph fast cut, or at least it is on my older model. It's getting tired now and peaks out at 6mph in level or a slight down slope. I maintain a 5.2 mph average moving speed over 5.7 miles of travel to cut around 3 acres. See attached, I track my time and speed with GPS.
Ignore the 9mph Max speed, that's a GPS error of some sort. The only way it would go 9 mph is on a trailer!
/ Husqvarna GT48DXLS Compared to John Deere #177
I honestly think that Husqvarna is in a hurry to get their site updated before the start of the season as information keeps changing and moving around. One minute I can search for a model and it comes right up and the next minute I cannot find it without digging around.
So according to the site, there is a TS354X and a TS354XD, the only difference being the transaxle. So you have to choose between a locking diff (Tuff-Torq K66ELD), or the fast hydrostatic (Hydro-Gear G730) with the locker costing $100 more. In looking through the manuals and the illustrated parts lists, that appears to be the ONLY difference in them. I have spoken with my local dealer and these models will not be available until mid April. It is a darn shame that John Deere could not offer the K66ELD in their X380 for the same price they already sell it for. That would make the decision to go to the John Deere a bit easier. With their sale that just ended, the difference between the the X380 and the TS 348XD was only $500 with the Deere offering a better engine, better warranty and overall better build quality. But now at a $1,000 difference, it make the Husqvarna look more attractive. The only gripe I have now is that Husqvarna still continues to use steel bushings on the front wheels instead of ball bearings. Yes, it is easy to maintain and even replace when they wear, but the bearings in the X300 or even Cub Cadet XT2 series is a good move for reliability.
/ Husqvarna GT48DXLS Compared to John Deere #178
I scratch my head wondering why guys want to mow like it's the Indy 500. My JD X590 tops out at 7mph but I never mow that fast. The only time I go that fast is when I get a wild hair to do some hot doggin'.
/ Husqvarna GT48DXLS Compared to John Deere #179
With 580 hours on my bushings and they aren't worn bad, I don't really see that as an issue. I grease my tractor every 8 to 10 hours, so I think that if an owner Jeeps them nice and wet with grease, the replacement interval isn't quick enough to be a big deterrent. I've replaced 2 more deck spindles, one deck belt, one deck belt tension spring and 2 batteries in my hours/years. Not bad for a $2,800 tractor from Sears
/ Husqvarna GT48DXLS Compared to John Deere #180
The X590 is a beautiful machine and I would certainly have one if I could afford it. The K72 in the new ones is a very robust transaxle and there are few rider type mowers out there today that can compare to the quality, features and specs without jumping up into the X700 Deere or the dielsel powered subcompacts. I think Simplicity makes a model called the Legaxy that starts to get up there in features but I am not sure as to the quality or warranty.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2022 Mack Pinnacle Day Cab Tractor w/ Wet Line Kit (A61568)
2022 Mack Pinnacle...
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
