Buying Advice In a Quandry
/ In a Quandry #1
Citizen Dick
ny,ky
none
having purchased 100 acres in KY, varying terrain, half wooded, looking to build a small farm/homestead for myself and grandkids, I am thinking of purchasing a Branson 3520 shuttle shift, or 4520 shuttle shift brand new. Tractor will be used for every imaginable task (plowing, seeding, raking, baling, earth moving, wood hauling, etc.)... I am interested in what others think...
/ In a Quandry #2
Unless you are retired, you need to go bigger, you need to get the work done, not play at it. Look at utility tractors, not compact utilities.
Good luck. :thumbsup:
/ In a Quandry #3
I agree. For that much land, you need something that can get the job done. You will overwork a small tractor, and eventually destroy it. In a few years, the novelty will wear off and the land will become work. Some of it extremely enjoyable work, some of it time consuming could be better spent doing what you enjoy. Mowing is one of those things. You want to be able to mow as much land, as quickly as possible. A 15 foot batwing will need a 80 HP tractor at the bare minimum. I'm personally hoping to upgrade to a 90 to 100 HP cab tractor when I finish paying off my wife's mini van for my 68 acres. Cab so I can use it regardless of how cold or hot it is, and not be attacked by bugs.
/ In a Quandry
thanks, I appreciate the input... what size would you recommend?
/ In a Quandry
thanks for the response... my plan is to have 2 acres for house and yard, minimum of 25 acres woods, 10 for foodstuffs, the rest planted in grass, most likely rye since it's good to make whiskey from... what would you recommend for size? and do you see an issue with Branson as a brand? I ask because their tractors seem to offer more for the dollar.
/ In a Quandry #6
You seem to be looking at Branson, so the 45 series would be a good place to start. What other makes are within an hours drive? Go look at them also. Pretty much all of the newer tractors are pretty good. You just need to find one that fits you, as in the controls are comfortable for YOU to operate. Best to at least sit on as many different makes and models that you can before making a final decision.
Frame sizes of utility tractors usually START at around 60hp and go up from there. If a frame size ends up in the 60hp range, it usually is at the upper end of a compact utility lineup.
Do some research, then go and look. ;)
/ In a Quandry #7
I don't know why everyone thinks you need 100 HP and a 15ft.batwing for 100 acres.I couldn't even turn a rig that big around on "my" 100 acres.I do all the jobs the O.P.described with 44 HP.
I have small food plots(ten or so)from 1/4 to 2 acres;20 acres of wood lot,lots of fence rows and stone walls. I brush-hog maybe 20 acres total of that once a year with a six ft.Brush-hog.
I don't bale any hay but I know they make small balers.
/ In a Quandry
I have been doing the research and my head hurts from it LOL.... been looking online for basic info, and going to fairs and actually trying out the equipment, however, at county fairs and such, the people you meet are generally sales people, not users, hence my joining this forum; the desire to talk to people that actually use the equipment... my interest in Branson tractors is nothing more than economics; they seem to offer the best value price-wise, but I have never seen any of their equipment out in the fields or woods working...
/ In a Quandry #9
The best way to shop for tractors is to list your tasks first, then determine how much bare tractor weight you need to SAFELY accomplish your tasks. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models.
For most tractor tasks greater chassis weight is more important than tractor horsepower. This tractor fundamental is difficult for people new to tractors to comprehend. It takes a 50% increase in bare tractor weight before you notice a significant tractor capability increase. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Heavier tractors have more tractive power pulling ground contact implements. Greater mass of heavy-chassis tractors increases tractor stability when transporting loads in the FEL bucket, the most rollover prone of routine tractor tasks. Heavier tractors have larger wheels and tires better able to bridge holes, ruts and downed tree limbs, yielding a smoother, less disturbing passage over rough ground.
Safe hillside operation demands more tractor weight than flat land operation. Heavier tractors have wider wheel spreads making heavier tractors less laterally unstable. Rear wheel spreads may be decreased or increased after jacking up the rear.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Tractors under 3,000 pounds bare weight are offered in one configuration. Most, such as the high volume kubota standard L series, are sparely equipped to hit competitive price points. Others, such as the Yanmar YT235 and Kubota B2650/B3350 series, include enhanced productivity and comfort components.
Most tractors under 3,000 pounds bare weight are operated in residential applications on one to five fairly flat acres. These "residential tractors" fit in a typical garage.
Tractors over 3,000 pounds bare weight are generally offered in a utilitarian configuration and a deluxe configuration, on a common chassis. Deluxe kit enhances productivity and operating comfort ~~~ but you have to pay. Many tractors over 3,000 pounds bare weight are too tall to fit in a typical garage, even with ROPS folded.
Selling a used tractor is easy. Selling light implements in order to buy heavier, wider, implements for a heavier tractor you take a hit in depreciation. Passing time with multiple browsers is a pain. ((Ask me how I know.))
For most new to tractors a quality dealer, reasonably close, available for coaching, is important. Dealer proximity is less important to others, well experienced with tractors, who perform their own maintenance. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment.
Horsepower is only a primary consideration operating PTO powered implements.
BUY ENOUGH TRACTOR.
/ In a Quandry #10
What's your budget?
/ In a Quandry
Thanks for your response, I do appreciate it and am looking for input from as many sources as are available... I can understand that someone would want to accomplish a chore in as little time as possible, but until 1940 or so, farmers were using tractors of less than 30 HP for farms of 100 acres, so I do take that into consideration also... the other half of the equation is balancing work on the land with my full-time job... ultimately though, I believe the most important thing is teaching my grandkids that the land is all that matters, well, after family, and that "dirt don't hurt"
/ In a Quandry
What's your budget?
I am looking to spend no more than 35k for a tractor and at that price I can get a tractor , brush hog, box scraper, post hole digger with 12" bit, backhoe and trailer new... i know I need other things like a seeder, tedder, baler, etc. so I am not opposed to purchasing used equipment either... that being said, I prefer new equipment only because if it is new I know who used it, and in what manner...
/ In a Quandry #13
BUY ENOUGH TRACTOR.
Very well put! You might want to listen to this.
/ In a Quandry
BUY ENOUGH TRACTOR.
thanks a lot for that response... you've given me a lot more to consider :thumbsup:
/ In a Quandry #15
Do you have experience operating a tractor?
Do you intend to perform your own maintenance and repairs?
How far is it to your nearest Branson dealer? (There are only 165 Branson dealers in the USA.)
Branson 4500 series begins at 5,700 pounds, bare tractor. Sufficient weight for every task you have itemized.
When shopping other tractor brands, new or used, try to focus on tractors from 5,000 to 6,000 pounds bare weight.
Of the tasks you have itemized in Post #1 it is baling hay that requires tractor weight and horsepower, especially large, round bales. However, I doubt you can profitably raise and sell hay on 50 to 60 acres. The equipment is too expensive and processing too weather dependent for a part time farmer.
If you rent your hay field, or farm it on shares with someone who has equipment, you can get by with a 4,000 to 5,000 pound bare weight tractor. You then have a business, with all a businesses tax advantages, especially depreciation.
/ In a Quandry
I have operated articulated loaders, fork lifts, man lifts etc., not farm tractors per se, and I am a mechanic by trade, so maintaining the equipment will not be an issue in my mind... nearest Branson dealer is 500 miles, so that may be an issue
/ In a Quandry #18
You will get diverse advice here.
You have to pick and choose the advice which is most helpful to YOUR conditions.
The diversity of opinions is T-B-N's strength.
/ In a Quandry #19
Great background.
However, I would want a dealer within thirty miles, tops. You will not have any warranty coverage from 500 miles away. New tractors almost always have some new tractor issues.
/ In a Quandry
I agree completely... knowledge is gained from listening to those who have the experience in what one is considering and applying it to what they themselves have already experienced... I know that ultimately I will come to a conclusion that will benefit myself in all ways.
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65057)
2001...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
Lot Five (A3632137)
Lot Five (A3632137)
17601CFL (A61572)
17601CFL (A61572)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
