Mahindra 2655 hst cab vs Kioti nx5510hc.
   / Mahindra 2655 hst cab vs Kioti nx5510hc. #11
That’s the thing you have to be comfortable in the seat if not you’ll never be happy with it. It sounds like you really like the kioti and I don’t think you can go wrong either way as long as your not like a pretzel trying to drive.
   / Mahindra 2655 hst cab vs Kioti nx5510hc. #13
If you like the Kioti, why not get the Kioti? I did. Kioti's are good tough tractors with a lot of good features at a good price.
Even my little tractor has tilt steering wheel. They have good ergonomics overall.
   / Mahindra 2655 hst cab vs Kioti nx5510hc. #14
I don't have a dog in the fight but seems there are a lot of negatives about Mahindra;I do know someone that has purchased four Kioti tractors(contractor) TLB's and he is about as fussy as I know so if he is happy they must be decent.
If I go with the Kioti my implements are too narrow. If I decided to go that way then I would have to look at the Mahindra 3550 which is a beautiful tractor but I think more money. The specs on the mahindra 2655 are better for the loader. I hire out with the tractor so lift is important. The 2655 is just narrow enough my implements would work. One thing I did notice on the spec sheet is that the Kioti has 2 inches more ground clearance and is about 6 inches shorter up top. That is a plus in the woods. Wish I hated my mahindra dealer :)
   / Mahindra 2655 hst cab vs Kioti nx5510hc. #16
Maybe you could learn to love your Kioti dealer too. "if you can't be with the one you love, love the one your with". :D
lol. I like it. I just got back from a quick test drive of a nx6010hc and really liked it. I will be back at the show tomorrow for more pricing now that I have driven one. Got a price of 35,500 minus 17500 for my 2538. Tomorrow I look closer at all brands as I may move away from Mahindra. I had to drive an hour to this Kioti dealer but it is what it is. Monday sounds like a good day to make an appt. for a final test drive of whatever it is. I really do not want to wait for Mahindra to redesign me a tractor
   / Mahindra 2655 hst cab vs Kioti nx5510hc. #18
Look, if one tractor fits you and another doesn't, you don't owe anything to a particular paint color. If you believe the other dealer will support you like you need to be supported, then I say go for it. Just as I would say if the red tractor fit you and you liked the dealer, then you should go for that. My Korean tractor has worked well for me now for about 6 years, and I came out of a Kubota into this Korean shade of orange.
I got it for $19,200 with the canopy and a good trade in on my Kubota. More lift, on the FEL and way more useful features. Like telescoping lower links, telescoping side sway bars, Rear 3pt lever for hooking up, a rear hydraulic hookup standard, and a 2nd one available for small dollars. Twin Touch hydro pedals. Easily reachable SCV lever, Tilt steering wheel, Cruise control, Electric/hydraulic 4wd control and Electric/hydraulic PTO control Fully adjustable suspension seat. All of these things make operation much easier.
Now if my implements were wider......
   / Mahindra 2655 hst cab vs Kioti nx5510hc. #20
I kept mine from my little B7500 on to the L3400 and now my Kioti DK35se. I just used them anyway. I had to get another onger drive shaft for my little rotary cutter, but it still works, It is just that I could run a much wider one, but for no more brush cutting I do, it works fine. I still use my 5ft rear blade too.
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2012 CM  T/A ENCLOSED 14 TRAILER (A55745)
2012 CM T/A...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
