Chain Saw Holder
/ Chain Saw Holder #21
Wow, I didn't expect this kind of response! Thanks for the comments.
There is a reason for the backwards graphic even though I could have assembled it the other way:
It was both very cold and humid the day I panted it and the other side of the outward plate has a nasty drip on it.
I do plan on repainting it once the weather permits because I don't like it backwards either!
@blackdog2086 - I would be tempted to produce more the design should allow it to be mounted on anything just by changing the brackets.
Fortunately I do have access to a CNC table, that also means I could have another one ready for paint in about 10-15 min
@rlgustafson, I'd take that challenge!
Anxious to see what you come up with. Both of my tractors have cabs, so I haul the pole saw around in my Polaris Ranger to do trimming then back with one of the tractors with grapples to pick up limbs.
/ Chain Saw Holder
You wouldn't happen to have a model# of a pole saw I could use as reference?
/ Chain Saw Holder #24
Now .... if someone would come up with a good, safe way to carry a power pole saw on a tractor.
I have been thinking about using 2 of these,,,
search "boom pole holder" on eBay.
Oh, by the way,, the OP's chain saw holder looks great,,
My SIL destroyed one saw when it jumped out of the loader bucket.
Now,, he hand carries the new saw around his property,,, :laughing:
/ Chain Saw Holder #25
You could use one of these holders but, how would you use two of them? The “pole” has to go under one end and over the other end.
/ Chain Saw Holder #27
/ Chain Saw Holder #28
That thing is a bit over 9ft collapsed!
It could run down the side of the tractor but you would loose ingress/egress ability on one side while in the mounts. Mounting high could work but then it could be difficult to taking it on and off.
I would be very concerned that I would snag a pole saw on something I did not see and ruin it. Particularly in the woods or around any tree.
/ Chain Saw Holder #30
Really nice looking job. My logging winch came with a chainsaw mount but I have been thinking about relocating it to a better spot. I may move it to a similar spot under the loader control but it still won't look as nice as yours.
/ Chain Saw Holder #32
Nice work. Not many guys would have the vision to build a chainsaw holder that approaches being artwork.
It is nice!! My chainsaw holder is close to the same location, it's inboard of the FEL mast on the right side. But, sadly, mine has no artwork on it, it's just green. :( I still like it, though. :p
/ Chain Saw Holder #33
I bought a JD950 with a loader and recently rebuilt the engine. I currently have the front 4WD hubs apart to re-seal. Now I realize I not only need to build a mount for my chainsaw I also need to buy a saw that matches my tractor :rolleyes:
I will be using this tractor in the timber. Hadn't thought thru the saw thing! Nice work on the mount!
/ Chain Saw Holder #34
Ha ha, Good luck on a green saw!
/ Chain Saw Holder #39
I’ve seen some nice ones made out of those deldrin or plastic cutting boards. Guy had enough to cut it up, and sandwich the bar, and used two strips on both sides as spacers, and it protected the chain as well. I thought it was a clever idea.
/ Chain Saw Holder #40
This is what I planned to do for a future BX mod. Got to design in some 'orange' features too. :D
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2 Row Cultivator (A64047)
2 Row Cultivator...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2013 BMW 550i AWD Sedan (A61574)
2013 BMW 550i AWD...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
