Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,242
I hear ya about the oil temp. when its really cold it can take a good 20-30 minutes at my first account to get the hydraulics warmed up. Until then it can barely get out of its own way.
My oil cools down between properties and so it never seems to be able to pull a high gear plowing.
   / Pictures of your snow weapons #4,243
Just got my boss 7.5ft sport duty mounted to my ck2610. It works great so far. I can switch the plow between my tractor and truck now. View attachment 540343 20180217_081549.jpg
   / Pictures of your snow weapons #4,244
   / Pictures of your snow weapons #4,245
Why didn't you mount the plow slot closer?? Would be less stress to the front axle I would think
Probably because the plow brackets are the only piece that could practically be shortened and it wouldn’t fit his truck then. The plow should still be a lot less stressful on the axel than the loader.
   / Pictures of your snow weapons #4,246
The plow is no further out then the bucket. And I can just barely open the hood where the plow is now. And at 400lbs the plow isn't nothing the tractor at all.
Not to say closer wouldn't be better.
   / Pictures of your snow weapons #4,247
I only got a few inches. Didnt even plow it. All ice was gone. Im ready for spring.
Me to. what a difference a day makes ... Another foot just fell
   / Pictures of your snow weapons #4,248
That makes sense. All my accounts are within a few miles of eachother in a downtown area so I get to just drive between them and the oil never gets a chance to get cold. It would be nice if they came with hydraulic temp gauges. Now im curious how hard it would be to add one.
   / Pictures of your snow weapons #4,250
Looks good, have you considered a brace back to the mid or rear section of the tractor.
A truck has a full length frame where as the tractor front is a sub frame tied to the front of the engine,
It wasn't many years ago when our truck, jeep and scout plows actually had attachment points under the cabs
back about where the seats mounted.
3 Point Hitch Hay Spear (A57454)
3 Point Hitch Hay...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
Valve Grinder Set (A57454)
Valve Grinder Set...
