Hydrailic quick connect question
/ Hydrailic quick connect question #1
rasorbackq
Springfield Nova Scotia Canada
Branson 4720
Does it matter which way the quick connects are facing on a hydraulic hose.
Installed a grapple clamp yesterday and within 10 minutes the male end was broken off just above the row of bearing in the female . Thought I had lots of hose so no stress that way.
/ Hydrailic quick connect question #2
I don't think it matters, I installed mine with the male ends on the cylinder side
/ Hydrailic quick connect question #3
Sounds like your hoses are to short, not a QC problem unless it was just defective from the start.
/ Hydrailic quick connect question #4
The length between Curl and Rollback of the loader is pretty LONG... I would measure it again...
/ Hydrailic quick connect question #5
Grapple hoses have to be stupid long. Possibly drooping down and touching or almost touching the ground when the bucket is sitting flat on the ground. I've considered different methods of holding these hoses up off the ground but haven't followed thru with any.
All factory systems put the female end of the coupler toward the pressure source. Male end toward the powered cylinder or attachment.
I remove my Grapple frequently. I mounted one female and one male to the tractor. Cylinders hoses have one female and one male. No confusion when recoupling.
/ Hydrailic quick connect question #6
I like the male end to be on whichever component is most likely to fall in the dirt. It's much easier cleaning the male end than it is the female end.
/ Hydrailic quick connect question #7
That's exactly what I do as well. Then, when you have the grapple unhooked you can keep both hyd ends on the grapple plugged into each other, (same with the tractor side), things stay clean and the pressures stay even.
2015 KENWORTH T880 (A67714)
2015 KENWORTH T880...
55 GALLON BARREL TOTE/ OVERHEAD CREEPER (A67714)
55 GALLON BARREL...
2016 Ford Escape AWD SUV (A66738)
2016 Ford Escape...
2021 WESTERN STAR 4700 DUMP TRUCK (A67714)
2021 WESTERN STAR...
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
