3-Point Hitch 2555 additional rear remote
/ 2555 additional rear remote #1
sjp649
Member
Indiantown, Florida
Mahindra 2555 Shuttle
Looking add 1 or 2 more rear remotes to the current stock one. I'd like to try and use factory stuff so it looks good to. Any ideas and where I can buy a kit?
/ 2555 additional rear remote #2
You can order the kit from any Mahindra/TYM dealer. You can add two additional rear remotes for a total of 3. If you decide to add 2 additional, you'll have to buy the longer studs also.
Thank you. Have a call into my dealer already
/ 2555 additional rear remote #4
I am looking to add also. Let us know how things pan out.
/ 2555 additional rear remote #5
My local Mahindra dealer was adding the 2nd & 3rd rear remotes to a 2565 so that the guy could have a top & tilt set and operate hydraulic actuated rippers on his box blade. I saw the 2 valve kits, seemed like it was going to be a pretty easy installation to me. :thumbsup:
/ 2555 additional rear remote #6
Any word on the cost for each kit? I will install myself.
/ 2555 additional rear remote #7
Remember to specify what kind of remote you want....the Mahindra 2500 series has 3 styles: Fwd/Neutral/Rev Detent, FWD/Neutral/Rev Momentary return to neutral, and Fwd/Neutral/Rev Momentary with a Detent Float. If you need constant flow stick with the stock detent style...but if you are running mower outriggers or anything with cylinders controlled by the valve in the cab...the momentary ones work better for that.
/ 2555 additional rear remote #8
I have one on there now with the detent function I would like to add a momentary for a hydraulic top link. Does anyone know if the rear remote was standard equipment on my 1016 2565 cab shuttle? I recently bought it used.
/ 2555 additional rear remote #9
I believe that the 2565s come with a single rear remote std and an additional 2 sets are available.
/ 2555 additional rear remote #10
My 2565 came with one rear remote, I also added a second one.
/ 2555 additional rear remote #11
I have a JD2555 and the company that it came from (used) often throws me some of the extra parts as they pop-up in their way on shelves. I got a pair of rear remotes to add to my pair so I naturally clicked on this post, only to realize that it wasn't a green tractor you were looking for remotes to install.
David from jax
/ 2555 additional rear remote #12
Thats ok David. "It ain't easy being green". Some remote kits aren't brand specific.
/ 2555 additional rear remote #13
I had triple rear remotes installed on my 2008 Mahindra 5525 by the dealer. His own design. $750 option.
It helps to have flat top fenders. Makes the installation easier.
Best to get options like this when you buy the tractor rather than retrofitting.
Good luck.
/ 2555 additional rear remote #14
Old thread, I know, hoping you could share how you added additional remotes? looking to add a second remote on my 2665
/ 2555 additional rear remote #15
They stack. Remove bolts in existing, place new valve body on top of existing, replace bolts with longer ones.
/ 2555 additional rear remote #16
Yep easy set up on non cab tractor it gets a bit complex with the cab tractor and real hard to find some TYM built tractor kits and very expensive, i could not find one for my 2660 cab TYM built tractor at a reasonable price with plans to use in place of a 3 function, both were way above $1000 so i found a company that makes a kit that once installed it can take the scope and rooal function of the loader ad use for in my case my grapple or in other cases a rear remote
/ 2555 additional rear remote #17
The kit was $625 shipped and tax to me
2017 Maserati Ghibli Sedan (A64557)
2017 Maserati...
2021 LUCON MRT3500 SPOOL TRAILER (A63276)
2021 LUCON MRT3500...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
UNVERFERTH 14' FIELD CULTIVATOR (A64278)
UNVERFERTH 14'...
