tn 75 da will not move
/ tn 75 da will not move #1
bo69
McLoud
TN 75 DA New Holland
I replaced the engine wiring harness on my TN 75 DA new holland rat got on the warm engine and chewed it up now it runs but will not move forward or backward no codes are showing up and don't see any more bad wires can anyone give me some help on what is going on with my tractor Thanks
/ tn 75 da will not move #2
Check the transmission electrical connectors for loose connections, corrosion , rat damage, etc.
/ tn 75 da will not move #3
Only other thing would be to ensure the harness was the correct one?? All wires had a place on the new harness. No extra connectors hanging unplugged??
Another thing to check is wiring grounds. Making sure there's not an individual ground wire chewed in two somewhere??
I can't think there's any technical procedures that would need performed to "reset" the trans module.
But then, we don't know if there were any time when a "short" was created by the chewing which could possibly damage the trans system. Is the tractor electronic power shuttle or electronic power shift??
/ tn 75 da will not move #4
Do any computer parameters need to be down loaded, or reset?
/ tn 75 da will not move #5
Same thing happened to my TN75...what did you have to do to get shuttle shift going?
/ tn 75 da will not move #6
Left side on the chassis has 3 solenoids 2 of them are one on top the other they are responsible for foward and reverse n the one to the back is for clutch smoothness and immobilisation . Sometimes it's stuck closed allowing immobilisation but most times it's just ur hydraulic filter , bleeding the hydraulic system on these things are stupid annoying. But if ur steering is nice and easy while engine on but still won't move then the system is well bleeded and could be that solenoid. If it's getting a solid 12 volts u won't go anywhere
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
Mini Skid Steer (A60352)
Mini Skid Steer...
2013 John Deere 8360RT Track Tractor (A63109)
2013 John Deere...
