Ford 3400 Ignition switch replacement
/ Ford 3400 Ignition switch replacement #1
daveinwestmi
Kalamazoo MI
Kubota L3560, BX2380
Helping a friend of a friend with a no start Ford 3400 gas. Turns over if jump direct from the battery to the S terminal on the solenoid so I guessing it the ignition switch. Does anybody know if the ignition switch can be replaced without pulling the dash panel that the steering column go through?
Thanks
Dave
/ Ford 3400 Ignition switch replacement #2
Thanks
Dave
I do not know, but please do respond when you complete the fix.
I have a gas 3400 TLB, so could you please PM me with the info, in case it should happen to me.
I am far from my tractor for the winter, so cannot go look at mine.
Yes it can. There should be just enough slack in the harness to get it down below the cowl.
Thanks RickB. Switch is ordered I'll report back when I have it and install it.
Thanks - Dave
Sudenga 10 x 63 Swing Away Auger (A66408)
Sudenga 10 x 63...
2022 EZ-GO ELITE...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
Dodge 5500 4x4 Altec Bucket Truck (A63689)
Dodge 5500 4x4...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
Hayrack Wagon (A66408)
