Ford 3400 Ignition switch replacement
/ Ford 3400 Ignition switch replacement #1
daveinwestmi
Kalamazoo MI
Kubota L3560, BX2380
Helping a friend of a friend with a no start Ford 3400 gas. Turns over if jump direct from the battery to the S terminal on the solenoid so I guessing it the ignition switch. Does anybody know if the ignition switch can be replaced without pulling the dash panel that the steering column go through?
Thanks
Dave
/ Ford 3400 Ignition switch replacement #2
Thanks
Dave
I do not know, but please do respond when you complete the fix.
I have a gas 3400 TLB, so could you please PM me with the info, in case it should happen to me.
I am far from my tractor for the winter, so cannot go look at mine.
Yes it can. There should be just enough slack in the harness to get it down below the cowl.
Thanks RickB. Switch is ordered I'll report back when I have it and install it.
Thanks - Dave
8ft. Metal Drag (A65640)
8ft. Metal Drag...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
2021 YANMAR VIO35-6A EXCAVATOR (A63276)
2021 YANMAR...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
