How much does a load of fill dirt cost typically?
   / How much does a load of fill dirt cost typically?
So got a couple estimates:
- Dual axle load of 16 yards for $120
- One "load" for $175; don't know what a load is yet, but I suspect it's a single axle dump truck load - which would be how many yards, typically?
I plan to supplement this dirt with dirt from my own place. But at 1/2 yard max, it will take some diesel as one mentioned here, to get what I want or plan.
   / How much does a load of fill dirt cost typically? #12
Check with your county road crew, sometimes they'll drop off a load for "free". It's your taxes at work.
I second this...if you are looking for fill dirt during the time of year the county is re-grading the ditches, you can get your hands on a lot of dirt in a hurry.
   / How much does a load of fill dirt cost typically? #13
A dump truck load of dirt doesn't go very far......
Might be wise to spend a few minutes with your calculator to estimate how many yards of material you are talking about.
Couple years ago I raised two pond dams with my tractor and a 5yd scraper. I learned the true size of a cubic yard of material. :)
   / How much does a load of fill dirt cost typically? #14
Ouch...I'm getting screwed. I think I'm paying around $265 per tandem load delivered. Not sure the yds, but same amount of material as about 16-17T of crush & run gravel.
Next time I'm out there I can take a pic and show you how I constructed mine to save a little dirt and stay at 8' heights. Basically a 3-sided box with 4x4 - something for the pile of dirt to rest against so it will pile "up" vs just spreading out into a bigger heap past 4' high or so.
I did and I came up with 45 yards +/-.
bh/2*l*1/27. b = 10 feet, h =8 feet, l =30 feet long. Divide by 27 to convert from cu ft. to cu yards:
80/2*30/27 = 1200/27 = ~45 cu yards
Please do! Thanks!
   / How much does a load of fill dirt cost typically? #17
I want it dumped in amongst my Poplar grove and it's supposed to rain the next couple days. :(
I don't think a truck driver is going to be too happy if he gets his truck buried. Can you get it close and move it the rest of the way with the tractor?
   / How much does a load of fill dirt cost typically? #18
They’re more than likely not going to cross unproven ground this time a year.
   / How much does a load of fill dirt cost typically? #19
Totally a geographical issue.
Yep....that right there. Look in yellow pages for 'trucking companies' and on Craig's List for hauling, and find yourself an independent dump truck guy. I have a retired guy that runs his own truck 2-3 days week and will haul anything I want....gravel, dirt, chicken manure, sand....anything for a flat rate. He generally knows where to get dirt based on who is excavating what, and can get the dirt for little or nothing so I simply pay his haul bill.
I have to a) decide on the actual site, b) get rid of a couple of the Poplars to make room for the pistol range (yea, more Poplar firewood :( and c) put down some gravel for him to run on. So the site will be prepared to a certain extent.
I got the gravel I plan to use from him about 2 years ago or so. So when we talked about where I wanted the dirt, he was familiar where I wanted it; he didn't seem to have a problem, other than it being wet. We have a lot of rock around; mud not so much, so I have that as advantage as well.
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54756)
BUNDLE OF 4" - 6"...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
Killbros Fold-up Rolling Basket (A50775)
Killbros Fold-up...
2020 Deere 325G (A50123)
2020 Deere 325G...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
