Cummins 5.9 UNEVEN ring end gaps
/ Cummins 5.9 UNEVEN ring end gaps #1
fitterski
Gold Member
Nouvelle, QC
1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
i noticed that the nanual gives end gaps as folows
page V-30
oil control: .010-.022
page V-31
top ring: .012-.018
intermediate ring: .032-.047
bottom (oil) ring: .010-.023
The oil ring spec max is incongruent .022 vs .023, this would make me lose confidence in the Cummins manual if I still had any left. In addition to that there are quite different values found on the net. I'm concerned mostly with the intermediate ring for which some widely divergent values can be found, down to as low as 1/2 the spec. The as-is gaps measured all fall within tolerance EXCEPT the intermediates ALL of which measure at around 1/2 the spec. On reaction this would prompt me to file down all the intermediates ...but wait a minute, something seems to be sticking out like a sore thumb here.
I've learned a long time ago to swing into paranoid verification mode on any doubt and here I already have 3 grounds for doubt. To begin with why would the middle ring need a much wider gap? And then why would the replacement rings all fall within spec as-is except the middle one but that in every single set?
/ Cummins 5.9 UNEVEN ring end gaps #2
0.001" difference for a ring end gap can safely be ignored, the only real danger is not enough ring end gap; if the ends touch, they will shortly destroy the piston, and perhaps many more parts.
Are the intermediate rings much more massive than the top ring?
/ Cummins 5.9 UNEVEN ring end gaps #3
I would call Cummins with your CPL number (on the timing gear cover by the injection pump) and see what the spec is for that particular engine configuration.
The only book I have left here is for a 2004 Dodge and it calls for the intermediate ring as .014-.0249" with a maximum of .029. I'm not surprised you find many differing specs because this engine was used in many applications at differing outputs. Some turbo, some NA, etc. Lots of CPL numbers.
No problem ignoring the single thou, but it IS a DISCREPANCY which in my book (not this manual) is inexcusable when all you make is engines and you charge $250cdn for your own publication. Otherwise no, the ring section is the same ballpark as the top one. I always presumed (never presume) that the sole purpose of a gap was to assure that the ends never touch in service. Maybe there IS a requirement here for an actual relief gap for some obscure reason?
What blows my fuse is that they took $250 cdn from me for manual that is physically falling apart and is poor in every other respect and for which I had given them the ser# of both my "12-valves" to make sure I get the right publication. Here I am, was all set up to do the crank and pistons on the weekend but can now sit on my hands till Monday instead. That 2004's gotta be a 24-valve but that's the range of numbers I've seen spread around for 12-valves also. The last thing I wanna do is file down if I don't have to. The rings came in PAI piston kits (111336, oem cum3802494), they're a major supplier which is why I stopped upon seeing the sore-thumb difference. BTW i see no other gap spec in the manual except 032-047.
Sorry, I don't wanna be ambiguous, it'e not the truck manual but the Cummins engine manual (#3666087)
/ Cummins 5.9 UNEVEN ring end gaps #7
The ends will only touch under high operating temps. As mentioned before, the CPL# makes a huge difference. and engine running at power band RPM for days at a time in a power unit or generator will have different needs/specs from one being used for automotive purposes. A naturally aspirated engine can have tighter ring gap tolerances than that of a turbo'd engine due to different combustion chamber temps. Also, don't act like you have never made a typo, the desk jockeys typing the service manuals are only human as well, a .001 difference is so negligible it's almost laughable.
/ Cummins 5.9 UNEVEN ring end gaps #8
Cummins Rocky Mountain in Gillette, Wy is open 24 hrs. 307-682-9611. The first question they ask will be the CPL number. Get your CPL number and call them. They have been very helpful to me. 24 hr parts is great too.
/ Cummins 5.9 UNEVEN ring end gaps #9
I've never re rung a diesel... Some piston groves have a "proud" ridge for the ring notch to fit in... Do the rings have a notch for that ridge ?? Do the ring grooves have a "proud" ridge ?? If so, measuring the ring gap, the ring notch must be where the groove ridge is located...
If my head is up my b#tt on this, sorry...
OK.... pulled my head out and searched...
When measuring piston ring end gap, check the gap with the rings at the top and the bottom of the bore. If the bore has taper wear (bores typically wear most at the top), the end gap will be larger at the top and smaller at the bottom of the bore. Use the bottom position to set the end gap.
I've built maybe half a dozen gas engines but only one other diesel (a Deutz 4 holer) and I never heard about that proud ridge. The bores are 20 over and straight but I measure 3-1/2 inches down in the hole anyway for no other reason in this case than that is the Cummins procedure. So reading your comments I immediately went and looked but didn't see anything of note except that the top ring groves seem to be treated, they are black in the grove as well as around it on the piston side.
We NEVER stop learning. I just came across another little tidbit last night, that the ring manufacturers use robotic machines and control the gap size down to 0.0001" which I thought was really nice of them. But I wondered why two of my rings would then only allow a 0.009 feeler gauge to slide in while it was obvious that the gap itself is easily 0.015 or more just eyeballing it. So I took out the magnifying glass on a hunch and there they were: little specs inside the gap on one ring end. So much for automated machines doing 0.0001 :confused:
The weekend is over, I'm gonna sort this gap business out tomorrow. My curiosity insists on finding out why the middle ring would need double the gap which only some plastic material would justify on the basis of thermal expansion IF that figure is right in the first place.
/ Cummins 5.9 UNEVEN ring end gaps #11
Here's a theory... The top ring is the compression ring... If the second ring had less of a gap, it "might" or would become the compression ring... Maybe that's why they want more of a gap...
It's over my head, been a long time since when I was sittin' in class for basic engine theory! Yes, it's a compression ring too, catches maybe the 1/4 that got past the top ring but it's also an oil wiper, a finishing wiper like a windshield wiper. Explosion pressures in the head of the cannon get behind the ring to force it against the barrel wall (it's not the spring load that does this). So just maybe (here's MY theory) the finishing scraper function of this pointed sharp blade-edge ring doesn't really wanna be forced that hard against the barrel and to accomplish this a bigger gap gives some 'relief'. Now _I_ can get ready for my head up the u-know where scene :laughing:
Banned Super Bowl Commercial - YouTube
/ Cummins 5.9 UNEVEN ring end gaps #13
Do the instructions recommend offsetting the ring gaps 180 deg. on the piston ?? Seems that would be the norm... with a back up compression ring installation..
What they want done is staggering the gaps 120 degrees from adjacent ones. For a while I wondered how the rings would keep from turning, I guess they just don't. I opened this engine with about 120,000 miles on it and they were still staggered.
This link (so far alone out of a dozen including 3 emails to Cummins) bore fruit! KUDOS to Rocky Mountain Cummins!!!!
Whaaaaaada a mess, don't know where to begin. The engine number is 44966271 and the CPL is 1550. This was the engine number given to the API piston-kit supplier who sent me piston kit # 111336 inside which is ring-kit #505081 with OEM equivalent Cummins numbers of 3802494 & 3802232 respectively. No one (else) has been able to give me so much as diddly squat including PAI. The problem is that if I want to do a pro job I have to know the individual ring part number as per the Cummins QS web manual @
Cummins QuickServe Online | COLA
(red dots are the closest to paper manual values)
This page shows like 9 different gap ranges for each of that many ring part numbers for top as well as intermediate rings i.e. you don't go ANYWHERE without the ring part number. PAI however were unable to give me so much as the equivalent OEM numbers for the rings in *their* set, so much for PAI!
The hard copy manual that I paid $250 for states
Top 012-018
Mid 032-047
Oil 010-022
If I had gone with these numbers when my instinct first rang the alarm and I posted the originating article I 'might' have OVER gapped to the tune of 2 or 3 times spec which in my book means immediate execution by the shop door. I didn't, went looking instead.
So the gal at Rocky Mountain Cummins said "piece of cake, I can give you the cummins RING numbers that go into that equivalent cummins kit ...my, my, my ..how hard can THIS be everyone out there (not meaning this forum of course)??????
*her* part numbers and QS-based gaps
Top: 3919050 016-030
Intermediate: 3904347 010-024
Oil: 3904349
So after having lost confidence in the $250 paper manual, in PAI, in internet blog sources that do not quote precise sources, I wondered if my kit supplier got me the right set in the first place for my engine? I was so happy to hear the gal give me actual ring part numbers that I forgot to verify with her against the actual engine number. So I called back: the PAI kit number is the correct one for 20 over-bore, but it has been replaced by 3802422 which in turn looks like having a different oil-ring number 3933585.
(I spoke to both girls working there today BTW, I don't feel empowered to name them). I think they desrve the parts-dept nobel award!
I now have half a mind to chuck the entire PAI kit and order me a Cummins kit as maybe I should have done in the first place.
/ Cummins 5.9 UNEVEN ring end gaps #16
Isn't that amazing...
Now for the lesson... The more you know, the more you realize how little you actually know... More coffee for me...
/ Cummins 5.9 UNEVEN ring end gaps #17
Glad you got it figured out. I was afraid you weren't going to try calling them. I figured they could help you. They have been very good in my experience.
A local mechanic who was also 'on it' for me for an hour and came back with yet another set of numbers close to mine but not the same said 1-800-CUMMINS was where I "should have" called. But that was after I had gotten my set of numbers. Anyway thanks to your link it's all done, aimed for 0.018 all around with a few overshot to 19 & 20. Tomorrow the pistons go in.
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2015 Ford F-350...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2017 John Deere 825i XUV Gas Utility Cart (A59228)
2017 John Deere...
(2) 3"X24" HYD CYLINDERS (A60430)
(2) 3"X24" HYD...
2019 CATERPILLAR 926M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
