Tires Kubota MX Series, 2-WD. Does front axle allow adjustment of front wheel spacing?
/ Kubota MX Series, 2-WD. Does front axle allow adjustment of front wheel spacing? #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
RE: Kubota 2-WD MX 4800/5200/5800
Do the two wheel drive versions of MX tractors front axles permit fairly easy adjustment of front wheel spread?
Like the 2-WD Ford 8N-2N-9N models and Ferguson tractors, or via some other process? Does the front end need to be elevated to change wheel spread?
Thank you for educating me.
/ Kubota MX Series, 2-WD. Does front axle allow adjustment of front wheel spacing? #2
If it's like the previous generation of MXs, yes it allows for the width to be changed easily. I'd have to check my manual, but I recall seeing that they offer a pretty wide range of configurations. Yeah, I think you're gonna have to lift the front to do it though. With the exception of spin out rims on the rear of a few older ag models, I've never seen a way to adjust the width without doing some heavy lifting.
/ Kubota MX Series, 2-WD. Does front axle allow adjustment of front wheel spacing? #3
Alright Jeff, since you're such a stand-up guy I went ahead and downloaded the manual and searched out the info. Here's the adjustment procedure: Screenshot_20180131-125500.png
And the possible configurations:Screenshot_20180131-125702.png
Ahhhhhhh.......
Thank you.
/ Kubota MX Series, 2-WD. Does front axle allow adjustment of front wheel spacing? #6
With a hydraulic jack to lift, you're done in 20-30 minutes or less. The MX in 2WD, for the right purpose, is a great tractor.
I am on my fifth tank of gas with the Stihl MS 461. I like it. I am being very careful.
MS 461 has increased the productivity of my chainsaw time by about 50%.
/ Kubota MX Series, 2-WD. Does front axle allow adjustment of front wheel spacing? #8
Glad to hear that you like it. It'll probably gain a little power each tank for the first dozen or so. A big saw sure is nice to have when the wood gets over 20". Not only does it make your time more effective, it will increase the lifespan of your 261 by taking the heavy lifting off its shoulders.
2016 JLG 1932ES ELECTRIC SCISSOR LIFT (A59823)
2016 JLG 1932ES...
Pemberton 9' Stacking Rake (A60462)
Pemberton 9'...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
John Deere 3025E (A53317)
John Deere 3025E...
HEAVYEQUIPMENT TIRES (A60736)
HEAVYEQUIPMENT...
