   / Your last generator Maintenance Run #1,473
Anyone remember back when you were poor and couldn't afford fireworks, so your mom would stuff a gas-soaked rag into a bag of flour and drop it off the 5 story tower in your back yard?
   / Your last generator Maintenance Run #1,474
No, but I am waiting for the video!
You lived at the Fire Hall, Grain Elevator, or Petticoat Junction ? :thumbsup:
Rgds, D.
   / Your last generator Maintenance Run #1,477
I'll take C. Petticoat Junction! AND I'll be hanging out at the water tower!
SR
   / Your last generator Maintenance Run #1,479
   / Your last generator Maintenance Run #1,480
shot a blast of carb cleaner into the air cleaner and it started first pull.
Moss Road, is this better than starting fluid? Less volatile but still more oomph than gas?
Does it create vapors that get things going?
Always wanted to know how that worked. Sounds like a smart move, like
using preheaters on a cold diesel.
As long as it's not hurting the engine.
I mean, a clean carb is a good carb, right?
I have used both and I much prefer starting fluid over carb cleaner for several reasons.
The starting fluid (ether) is a gas so it is atomized as soon as it leaves the can regardless of temperature. Also, the ones I use have a cylinder wall lubricant in them. Being 100% atomized immediately allows it to move into and thru the carb/intake system to the cylinders more quickly which helps the engine start faster, this is especially important if the battery you are using to crank the engine over with is on it's last breath due to age, temp or too much cranking.
The carb cleaner needs to evaporate to work, that can be a little slow at very low temps. As well, even a small shot of carb cleaner into a small engine's carb is a lot of fuel (relatively speaking) and can wash the oil off the cylinder walls.
Either work but I find the ether works far better, faster and is even cheaper to use.
DEWFPO
2006 FORD E-350 SUPER DUTY SERVICE VAN (A52706)
2006 FORD E-350...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
CAT Skid Steer (A50322)
CAT Skid Steer...
