Todays shop time.
/ Todays shop time. #441
I figured I would add to this since I finally made something. :D
Small woodstove made out of a propane tank. Fired it up for the first time to burn the junk off before it goes into our tarped in work area. I still need to add some things like the door to cover the lower vent.
Some day I'll have a garage like some folks here.
/ Todays shop time. #442
Mike, looks like a welcome addition to your work area - I (sorta) feel your pain (other than nowhere NEAR as cold), most of my metal working stuff is still waiting for a "real" shop, I don't mix metal and wood work areas and the wood work stuff was there first :rolleyes:
Here's a few shots of my "Hybrid" (part tarp, part steel, part fiberglass) metal/machinery work area, SORT of in chronological order -
Inside - DSCN1844.JPG - Outside(s) - DSCN2058.JPGDSCN2079.JPGDSCN2175.JPG - Roof over conex, + 14x24 work area, slab and (steel framed fiberglass) enclosure still to do - DSCN2206.JPGDSCN2235.JPGDSCN2306.JPGDSCN2308.JPGDSCN2805.JPG
Not shown are more tarps (til I get more time/energy, etc)... Steve
Oh, and yes those posts in the last pic WILL be vertical, lagged into the (not there yet) slab...
/ Todays shop time. #443
Ha, the tarped area you have is not that far off from what I have. Metal corrugated roof with a double layer of large pool winter covers over it all. In a couple sections are glass I have from old solar panels to give some natural light and a bit of plywood. My tractor, my son's 67 IH pickup and a bucket mount snowblower I'm working on is all shielded under there. Hopefully the stove will allow us to work out there with a bit of comfort.
/ Todays shop time. #444
I got a couple of gift certs at Lowes for Christmas so I decided to spend them before I forgot or lost them. I had read about the "Kobalt Quiet-Tech" oil-free double hot dog tank 2.4 CFM with double compressor being super quiet so I thought why not. I have a 25 year old Craftsman 36 gallon tank with 5.5?CFM that you need double hearing protection to work near it. I recently moved it to my boat shed addition (one insulated wall between my shop and it is still pretty loud. I also have a Puma oil reservoir type hot dog tank that is guessing about 2.5 CFM that I have been running in tandem with my Craftsman.
So the plan it to hook all three together and just not run the Craftsman but use it as a reservoir tank only unless I need lots of CFM. I lacked one male quick coupling to get it all together but I did get the Kobalt hooked up to my shop air. It is super quiet as advertised and pumps up rather fast. My 24" shop fan makes more than twice the noise. I think I am going to be pleased with it.
/ Todays shop time.
I worked on my fuel transfer tank. It’s a retired semi 50 gallon tank. It originally only had a 3/8 output. That wouldn’t be much flow. Now it’s got an 1-1/2” pipe thread. I’m hoping it’ll gravity flow through the filter, but I might have to take it out. IMG_0942.JPGIMG_0943.JPGIMG_0944.JPG
/ Todays shop time. #446
I worked on my fuel transfer tank. It’s a retired semi 50 gallon tank. It originally only had a 3/8 output. That wouldn’t be much flow. Now it’s got an 1-1/2” pipe thread. I’m hoping it’ll gravity flow through the filter, but I might have to take it out. View attachment 537727View attachment 537728View attachment 537729
My 300 gallon bulk diesel tank is elevated 7’ above ground. My piping is all 3/4” thru ball valve then Golden Rod Filter to hose. Out flow is at least 5-6 gallons per minute all on gravity flow.
/ Todays shop time.
If it was in a permanent spot I could get it 7 feet off the ground. I was hoping I’d have decent flow into the CTL from the back of my truck which is about 2 feet drop. Plan b was to pick the tank up with the loader to get more elevation.
/ Todays shop time. #448
Perhaps a stack of pallets to raise your tank? 50 gallons of diesel weighs about 350 Ib. plus the weight of your tank, filter, hose, etc.
How high is the fuel filler on your CTL?
My stand was about 5’ High when I got it used, I added 2’ of height and enlarged its base for stability.
/ Todays shop time.
It’s about a foot lower than my truck tailgate. I’d planned on strapping the tank at the front of the bed and lifting it up some. ( dump truck ) The tank is about a foot high on its mount so I’d potentially have 4 feet elevation difference. If that doesn’t work I’d just lift the tank with the loader and it lifts about 12 feet high.
/ Todays shop time. #450
If you use much fuel at all, that will get old real quick.
/ Todays shop time.
It’s the best option I have short of buying a several hundred dollar pump. There’s a 2 foot elevation change from the bottom of the tank to the CTL fill lid. If the filter restricts flow too much I’ll take it out. When I don’t need fuel somewhere else I’ll set it in the barn loft and that’ll take care of the tractor and lawn mower. The backhoe I don’t currently own and the CTL will hold over half the tank so lifting it twice with the loader doesn’t seem like that big of a problem. I welded mounts for a clevis on the tank bands to make lifting with a chain pretty trouble free.
/ Todays shop time. #452
Get a Golden Rod filter and you won’t have flow restrictions.
goldenrod filters from Northern Tool + Equipment
You can get them on Amazon, at Northern Tool, Tractor Supply.
/ Todays shop time. #453
Oh I understand, at least you will have a good start on a transfer tank if you ever decide to go with a pump. I also agree with Rick go with golden rod filters.
/ Todays shop time.
I scored 2 gate post. I’ve got 3 more but I’ll have to wait until I’ve got the CTL to get them out of the ground. IMG_0953.JPG
/ Todays shop time.
I made a bushing to put an impeller on a smaller shaft motor. This is a monster 3phase dust collector conversion into a less monster single phase dust collector. We’ll see how that works out. At least the price was right. IMG_0981.JPGIMG_0982.JPGIMG_0983.JPG
/ Todays shop time.
I made a side mount to end mount conversion bracket for the same project. IMG_1018.JPGIMG_1019.JPGIMG_1020.JPGIMG_1021.JPG
/ Todays shop time. #457
I built a personal gym for my wife (and with her help) in my office I gave up for this purpose. We put 8X5 mirror on the wall and installed flat TV connected to SAT above that. Wi-Fi was already there. I will put a carpet on the floor tomorrow and order internet connected bike so she (and possibly also myself) could race with our children over Internet. Peloton Bike | Indoor Exercise Bike with Online Streaming Classes
/ Todays shop time. #458
Sweet. We are just cleaning out our unfinished basement and having a contractor come out and finish it. We will be left with a bedroom, bathroom, common area, and most importantly a gym. Can’t wait to have a nice place to work out. Hoping for mirrors on the walls and also a tv or two. We do lots of video work out programs such as P90X and I am hoping to have more then one tv so no matter the exercise it is still in view. sure have come down in price. Any pics of your new gym?
/ Todays shop time. #459
Love our home gym. As I've gotten older, though, I find the hardest thing about workouts is getting past the procrastination and actually staying with them!
For those of us over 60, a friend tipped me off to this exercise program. Haven't started it yet. :)
/ Todays shop time. #460
That's a funny one:thumbsup:
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
