Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,271
Nice, clean boards, and you don't need to dry it!!
   / Tractors and wood! Show your pics #5,272
As Sawyer rob that is some of the best lumber I've ever seen how did you do it??
   / Tractors and wood! Show your pics #5,273
Sawyer Rob you must really have some good help to get that done so fast and so quick!!!! I just don't know how you do it. You must have some of the best help and Equipment in the world
   / Tractors and wood! Show your pics #5,275
So, I need to pull down some trees that are hung up on other trees. Some are very large oaks. I own a small 25hp tractor. After some research, it looks like a few snatch blocks and cable will do the trick. I don't believe I need to invest in any sort of winch attachment to do this, as I just cut wood for myself in my own woods. Maybe a hand winch like the More Power Puller would do the job, but that thing is over 300 bucks. So, could someone recommend a few snatch blocks and cable? Other thoughts?
Watch the sales at Harbor freight, you can get a 12,000# winch for that tractor for $300.
Or..... 65' of 3/8 cable for $35 before discount, snatch blocks $28 before discount & the 20% coupons are easy to get.
   / Tractors and wood! Show your pics #5,276
What’s the plan of attack. Cutting the base off the root ball and pulling backwards?
   / Tractors and wood! Show your pics #5,277
No roots attached.
I've rolled many leaners out of the tree they're hung up in. Wrap a chain around the trunk many times, then use a tractor, 4x4. or come-along to unwind the chain. Doesn't take nearly as much horse power / brute strength to roll a tree as it does to pull them down.
   / Tractors and wood! Show your pics #5,279
that is a great thought! thanks!
   / Tractors and wood! Show your pics #5,280
Here are some pics of the tree.
I plan on pulling the trunk of the tree away from the leaned on tree.
8-Shank Cultivator (A52128)
8-Shank Cultivator...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK (A51222)
2012 FREIGHTLINER...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
