Ck30 hydraulic leak
/ Ck30 hydraulic leak #1
atcNick
Longview, Texas
Still shopping
Ran her hard this week and running over rough terrain and woody debri... then this happened.. could it be as simple as tightening that nut
Ck 30 hydraulic leak - YouTube
It could be that simple. Have you tried it.
Nope, was towards the end of the day and my tools are in storage. I’m going to run out in the morning and give it a try though
/ Ck30 hydraulic leak #4
More likely the hardline is fractured at the ferrule, as in the photo. You can't really see it
until you back off the nut.
I put a guard around mine, as it is very exposed to impact, as you found out.
Was it difficult to replace?
/ Ck30 hydraulic leak #6
I've had to a few of these type hard lines and I ended up making a fitting to adapt to rubber hose. These were for machines on rough terrain all the time.
Anyone know how much hydraulic fluid he ck30 is suppose to hold
/ Ck30 hydraulic leak #9
7.9 gal. I’m sure that is with a dry sump and new filters.
/ Ck30 hydraulic leak #10
I have not had to replace this particular hardline on my CK30, but I was worried
about getting it whacked. The filter hangs down underneath also, with a "hit me"
sign on it.
The photo I posted was of a similar hardline that got whacked, but this one was
inside a McCormick HST tractor. In that case, I was able to rebend the line a bit,
cut 5/8" off the end, replace the ferrule and reassemble.
A similar thing could be done with the Kioti, but impact protection and possibly conversion
to hoses as CHEVY did still makes sense.
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
Kubota L2501 (A62177)
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
